broken motor mount!!!
Old Nov 14, 2005 | 08:54 AM
firstimer's Avatar
firstimer
Default broken motor mount!!!
It's been eons since I've done these, seem to recall... sometimes they're a snap, sometimes a pain in the a$$ !!! Looks like my headers are in the way to get the long bolt out. So, drop the headers? or will the bolt angle past them once it clears the front half of the mount? Any tips? Take it to a shop and bend over!?
Thanks.
p.s. driver side.
Old Nov 14, 2005 | 12:22 PM
desi's Avatar
desi
When I did mine, the headers were already out. The only suggestion I can give, is to spend the money and get the Energy Suspension mounts. I tried to install the cheap, made in overseas crap for hours before switching to ES. It's not a hard job, but requires lifting and alligning the motor. Use a piece of wood under the engine and put a small jack to lower/raise the engine to allign the mount.
Good luck
Old Nov 14, 2005 | 12:26 PM
Hauq`'s Avatar
Hauq`
After just putting my motor mounts in on my 75 there isn’t much maneuver room getting the bolt in or out. I also changed to urethane mounts, so that my have made the holes line up differently then stock.
Old Nov 14, 2005 | 05:22 PM
desi's Avatar
desi
Get 1/4 longer bolts. They make the job so much easier. Use grade 8 ONLY!!!!
Old Nov 14, 2005 | 06:31 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
anything less is unsafe and you'll be doing it again in the very near future!
Old Nov 14, 2005 | 06:55 PM
firstimer's Avatar
firstimer
Thanks for the tips, now if I decide to take this on, just hope it doesn't turn into a nightmare like the lower rad. hose was!!!
Old Nov 14, 2005 | 06:58 PM
firstimer's Avatar
firstimer
Thanks for the tips. Now if I decide to take this on, just hope it doesn't turn into a nightmare like the lower rad. hose was.
Old Nov 14, 2005 | 07:02 PM
firstimer's Avatar
firstimer
Default mount
Thanks for the tips. Now if I decide to take this on, hope it doesn't turn into a nightmare like the lower rad. hose was.
To broken motor mount!!!
