Finished the jeep box
Notice the nice alignment, the compact joint.
[IMG]
The unit fits very well and I find when I reach through the window and rock the steering wheel the front discs also move instantly.
I have installed the Coleman adapters so any lines should bolt right up
The control valve is split in two and the ball valve is locked in place and the actual control part of the valve is discarded. All lines under the car are gone.
It makes for a very neat undercarriage. Nothing hanging low.
Special Thank you to Jim Oneal/Pro South who put me on to the idea of the Jeep box and later provided me with a good unit.
Thanks Jim
Some questions:
Did you have to collapse (sp!) the column?
Is that the box that sells Corvette steering?
Pacha
NO I started with a stock Jeep box from a 2002 or 2003 jeep but the kits include everything required.
I prefer the jeep box to the steroids for it's neat installation and no lines running all over the place.
I can replace the box with any stock jeep box.
If a stock box is say 12 to 1 ratio. YOu turn the wheel, the box turns the pitman arm and then and only then does the control valve receive a signal to send fluid to the slave cylinder and turn the car.
Steering input must go through the box first.
With the Jeep box the slightest turn of the wheel immediately affects the valving. IN the jeep box the valving is right at the input of the box, not after the box.
The stock steering is a series of movement, the wheel , the teeth in the steering box, the pitman arm, the control valve , the power steering pump sending fluid to the slave cylinder and finally the slave cylinder turning the steering linkage.
Way too many middle men.
The jeep box is direct hooked to the control valve. It is the control vavle.
I rocked the steering wheel last night standing beside the car and the front wheel rocked back and forth matching the steering wheel.
I feel it is a more direct route.
Steve
Steve
It would be boring to put the car away in the fall and know I am bring it out just like ti went away.
There is always this hope, this looking forward to a much improved ride.
I am running out of things to do. I have been at it about 19 years.
You have a cage correct? How far towards the front of the car does the cage come? I ask because I see a lot of people talking about making this modification, but the single u-joint doesn't seem like it will handle the deflection caused by a stock frame twisting under load. You have also added numerous gussets and a strut bar. I think anyone considering mounting the box with a single u-joint should consider the total application. A person could run into some problems if their frame is twisting like a pretzel.
Just a thought.
Ken
I also ran a 2 1/2 inch heavy walled pipe through the frame behind the steering box to tie the inside 3/8th mounting plate to the outside frame rail where I ran a 1/8th plate too to increase the rigidity of this area.
I like welding in gussets and making things stronger.
Bee Jay
Bee Jay
I work about 2 hours a day 7 days a week on the car for relaxation. It is not work. It is play. It relaxes me. Makes me ok to live with.
I also spend at least 1 hour every night with my horse plus I shoe horses on the side to pay for the vet.
After work you have about 5 hours of free time. Why not make use of it. I also have a rule that at 9 oclock I sit down with the wife and spend some quiet time with her until bedtime at 10. Has worked for 40 years.
Bee Jay
Definately something I want to do!
