Finished the jeep box
Old Nov 18, 2005 | 05:08 PM
FKING1's Avatar
FKING1
Can one buy a complete kit that includes everything including the pump? If so , do you have the company's name? Is it Corvette Steering?
Thanks,
Fred
Old Nov 19, 2005 | 06:30 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Corvette Steering it is. I'm going to do this next winter when I have my motor out. This year it's the full interior rebuild.
Old Nov 19, 2005 | 09:10 PM
GTR1999's Avatar
GTR1999
Professional grade and quality as usual Norval. Is there any concern about the solid U joint instead of tthe insulating type rag joint? I would think you need absolute alignment with the steel joint, will it transfer any vibrations?
Gary
Old Nov 19, 2005 | 10:41 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Looks good Norval.
What did you do to mount the box to the frame? If you line the Jeep box up with the C3 attachments, one of the 4 bolts is above the frame and only 1 of the other 3 is close enough to use a C3 hole. And the C3 frame & box has a slight angle on it where the Jeep box is set up for a perfectly fore-aft frame rail.
Old Nov 20, 2005 | 07:13 AM
Jim Shea's Avatar
Jim Shea
Dave,
You must have taken a vacation the last few weeks. A previous post from Norval described in pictures and text how he went in and carved a section out of the frame; welded in a special plate with predrilled holes to match the Saginaw/Jeep steering gear. A lot of work; but what you would expect from Norval. (Note from his pictures how the steering gear input shaft exactly lines up to the steering column shaft.)
As he describes in this posting, he has the frame heavily reinforced to the point that my concern as to using a cardon joint rather than a flexible coupling has most likely been put to rest. You may recall that the Saginaw flexible coupling was designed to take up flex (fore/aft as well as side to side) between the chassis and body (among other things). A cardon joint takes up angle but not motion. In a steering system such as a C2/C3 Corvette or a first generation Camaro (where the steering column connects directly to the steering gear), that motion would typically be translate to high loadings into the lower bearing in the steering column.
Jim
Old Nov 20, 2005 | 05:45 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by ddecart
Looks good Norval.
Look at this post and you will see how I did mine.
http://forums.corvetteforum.com/show...169&forum_id=3
Old Nov 21, 2005 | 02:39 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim, How was that avoided in the old vehicles that had the steering column/steering box as one unit? (I'm thinking '50s era trucks.)
Old Nov 29, 2005 | 12:40 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
My specialty is horses, not cars.
Judging from the blower sticking outta that Vette, he knows a lot about a couple of DIFFERENT types of 'horses!'
