Speedo cable lube
Old Nov 16, 2005 | 01:42 PM
theandies's Avatar
theandies
Default Speedo cable lube
Has anyone used one of those speedo/tach cable lube tools? If so, how well do they work? What kind of lube do you use with them? I've always just used a little graphite powder worked in to the end where the inner cable comes out of the outer sleeve.
Old Nov 16, 2005 | 04:17 PM
Crash80's Avatar
Crash80
I took the inner cable out and slathered it in white lithium grease. I am not sure what those special luber beasts use but I think it might be the white grease.
Old Nov 16, 2005 | 04:18 PM
carl a's Avatar
carl a
when i bought all my new cables from corvette central i also bought this cable lube and lubed all my new cables before the install,,sorry but dont know about the tool,i did by hand,,its a graphite base just for cables so not to attract dirt ect like a petro base will and cause failure due to grit ,------------------------------------------------
Old Nov 16, 2005 | 08:39 PM
tmoneymoney4's Avatar
tmoneymoney4
i took the cable completely out and used white lithium grease, thats what i was told to do... i did it by hand too
To Speedo cable lube
