Pistons
Old Nov 16, 2005 | 11:21 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Pistons
What pistons came in a stock 75 L-48 thanks
Old Nov 17, 2005 | 02:50 AM
jackson's Avatar
jackson
DISHED, CAST Aluminum with 4 valve reliefs.
Old Nov 17, 2005 | 03:00 AM
comp's Avatar
comp
Old Nov 17, 2005 | 10:43 AM
flood's Avatar
flood
Why do they have 4 valve reliefs?
4v head time!
Old Nov 17, 2005 | 08:39 PM
fauxrs2's Avatar
fauxrs2
4v head time!
IIRC they have 4 valve reliefs so they can be installed in any location in the motor with no concern which way its inserted...all 2 vr pistons have a dot or other indicator of which side of the piston faces forward...by having 4 vr you can install it any way you like in the motor.
Old Nov 18, 2005 | 05:02 PM
jackson's Avatar
jackson
Almost any position.
Most 4vr pistons also have offset wrist pins ... offset ABOUT 0.060". Logic for offset ranges from helping minimize piston slap to effectively advancing/retarding cam timing ... I've never found universal concensus.
Most pistons with both 4vr & offset pins also have a dot, notch etc to indicate "to front".
To Pistons
