Setting Timing on '79
Old Nov 17, 2005 | 07:18 PM
79vetter's Avatar
79vetter
Default Setting Timing on '79
I have checked out Lars' paper on setting the timing but I wasn't clear if this was geared only towards Non-HEI systems. I have HEI and I want to set things up correctly. Which parts of his paper should I ignore if I have the HEI?
Also, where can I find these softer springs that he is referring to?
Old Nov 17, 2005 | 07:38 PM
Duke94's Avatar
Duke94
Works great for HEI which is what I have. The advance claptrap works the same on both HEI and points. You can get the springs at Jegs or Summit.
Old Nov 17, 2005 | 07:39 PM
page62's Avatar
page62
You can buy an HEI recurve kit at any auto parts store. Throw away the weights -- keep the stock ones. I've always used the lightest springs in the kit to set the timing at full advance. Works fine.
To Setting Timing on '79
