Running headers under floorboard
Old Nov 20, 2005 | 09:17 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Running headers under floorboard
I received my header kit and played with routing the pipes. My small block and big block headers look like they run up in the tunnel. Does anyone know if I can run the collector under the floorboard. The T-56 is tight around the tunnel and I want to avoid anymore heat than necessary.
For reference, my oil pan is 4" to 5" off the ground, so the headers will be about 3" off the ground.
Check out my handy dandy stands I welded up.
Old Nov 20, 2005 | 09:47 PM
gkull's Avatar
gkull
Those look like nice merge header collectors. I ran my pipes straight back to keep heat off the tranny. The stock dual pipe holes were to close to the tranny
Old Nov 20, 2005 | 10:02 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Can you email me a pic when you get a chance.
budman78@sbcglobal.net
Old Nov 20, 2005 | 11:46 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
This is under my black 79.
Mike
Old Nov 21, 2005 | 05:38 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks for the pic.
Old Nov 21, 2005 | 08:09 PM
72 RAY's Avatar
72 RAY
Budman78,
I have Stahl under chassis headers, with Dual 3" pipes all the way back. I notched the frame so I could keep them as High as possible. I don't have great pictures but here's what I have.
Old Dec 4, 2005 | 11:10 AM
gkull's Avatar
gkull
Full length 3 inch pipes with my custom modded Crossmember I built when I installed my 700R4 back in the late 80's
To Running headers under floorboard
