Vacuum Advance Problems
Old Nov 22, 2005 | 05:04 PM
chianesi's Avatar
chianesi
5th Gear
Default Vacuum Advance Problems
I have a 78 silver anniv. bone stcok, with a Q-jet carb 17059222.
After setting the initial advance, I went to plug the vacuum advance back in and it advanced the engine immediately, the full 20deg. I checked all avail ported vacuum ports on the carb, each one is pulling around 12 lbs. It goes to full vac advance at idle knowmatter which port its plugged into.
Here is a picture of the carb setup. The Vacuum Advance hose is noted at both ends with the letter 'A'.
Can anyone help me figure out why it goes to full vacuum advance at idle??
Old Nov 22, 2005 | 05:18 PM
Stewart's74's Avatar
Stewart's74
Springs missing. Vac advance can no good. Weights not lubed properly. These are possibilities. But then again, what do I know...I'm just a hobbiest.
Old Nov 22, 2005 | 06:05 PM
chianesi's Avatar
chianesi
5th Gear
I'll check it out and let you know...thx
Old Nov 22, 2005 | 09:53 PM
chianesi's Avatar
chianesi
5th Gear
Weights and springs are OK... But I thought if the vac can was bad it would pull and vac at all??
Old Nov 23, 2005 | 03:57 PM
lowbuck72's Avatar
lowbuck72
Did you set your timing with or without the vacuum advance hooked up, and did you set it at full advance to about 35 degrees BTDC at 2800-3000 rpm? Obviously if you're pulling vacuum at idle, it's not a ported vacuum source. It's hard to see on your picture where the line is going in your carb. Ported vacuum should be just above the throttle plate, zero vacuum at idle. Manifold vacuum is below the throttle plate.
Old Nov 23, 2005 | 04:17 PM
jackson's Avatar
jackson
Default replace vac can
Inside the vac can is a rubber diaphragm and a calibrated coil spring; neither are visible or servicable. The spring provides the majority of opposing force the vacuum signal pulls against. Suggest spring has probably broken. If so, replace the vac can ... easy & cheap $ fix.
Old Nov 23, 2005 | 05:14 PM
chianesi's Avatar
chianesi
5th Gear
That's the thing...all ports above the throttle plate are pulling about 12lbs of vacuum..mabye the problem lies within the carb.
Old Nov 23, 2005 | 05:28 PM
lars's Avatar
lars
Because it's supposed to.
Your car uses full manifold vacuum to the distributor through a thermal switch. The car will run best in this configuration. Ported vacuum on your car is used only for the EGR. The ported vacuum nipple on that carb is located in the lower throttle plate on the forward passenger side of the carb, sticking out at a 45-degree angle. That ported source should be connected to the EGR and not the distributor. All other ports on your carb are manifold vacuum - including the one to your distributor.
To Vacuum Advance Problems
