Q-jet cfm?
Old Nov 24, 2005 | 08:35 PM
vetteDreams69's Avatar
vetteDreams69
Cruising
Default Q-jet cfm?
69 350/350
I will soon be having my engine rebuilt. I cannot find the cfm specs. on the original Rochester QuadraJet carb.
To make the proper upgrade - I would like to know what I have now.
Where can I find the specs?
Old Nov 24, 2005 | 08:49 PM
page62's Avatar
page62
750 cfm. But why do you think replacing the Qjet is an "upgrade"?
Old Nov 24, 2005 | 09:06 PM
vetteDreams69
Cruising
Default You're right
At 750 cfm - there is no reason to change the carb.
I will just get a high flow filter, hotter cam, header, larger exhaust and maybe a Edelbrock manifold.
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I think what he means is what holley size he wants to run. He is probally going to buy what size the Q-jet is. Although on a stock enginbe I whould want a 750. The Q-jet idles fine becuase the first butterflys are small but the secondaries are big for WOT. I whould probally get a regular holley 550-600 for your stock SB.
Old Nov 25, 2005 | 06:17 AM
fast idle's Avatar
fast idle
i went the holley route and went back to the q jet.
Old Nov 25, 2005 | 08:17 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if you have a moderately modded small block for street use, a Qjet that is set up well and is in good working order will do everything you need it to!
Old Nov 25, 2005 | 09:02 AM
page62's Avatar
page62
You can pass on the high-flow fuel filter -- the stock unit will handle more fuel flow than you ever need. If you used as much fuel as a high-flow filter can handle, you'd have trouble making it to the gas station!
Old Nov 25, 2005 | 12:56 PM
lars's Avatar
lars
vetteD -
If you're going with the upgrades you mentioned, including the headers, bump the stock jet size on the Q-Jet up 2 sizes. This will produce much better throttle response, and will prevent a slight lean condition from your improved exhaust system. Be sure to check the stock jetting configuration for your carb and use that spec as a baseline for your tuning - most of these old carb have already been "creatively" jetted, so you can't trust the jetting in the carb to be "correct."
To Q-jet cfm?
