passing gear
Old Nov 25, 2005 | 08:19 AM
c3-shark's Avatar
c3-shark
Default passing gear
After swapping engines in my 81, my car seems to be stuck in passing gear. What could be keeping this automatic from working properly?It wont downshift on acceleration, and winds out on the freeway.other than this, it works perfectly.
Old Nov 25, 2005 | 08:26 AM
wnmech's Avatar
wnmech
I dont know a lot about 81's but if it is a computer controlled car the torque convertor clutch may be staying engaged. This has happened to an 82 cutlass that I had. If your transmission is computer controlled there should be a four prong connector that goes into the side of the transmission try unplugging it and driving the car.
Old Nov 25, 2005 | 09:34 AM
big_G's Avatar
big_G
Make sure the vacuum modulator is hooked up. A loss of vacuum will cause those symptoms. Check the kick-down cable adjustment while your at it.
Old Nov 25, 2005 | 05:00 PM
palazzopl's Avatar
palazzopl
make sure the cable is hooked up to the throttle linkage. If it is try to adjust it. It sounds like its to tight
Old Nov 25, 2005 | 05:19 PM
Pete K's Avatar
Pete K
Remove and inspect the governor. It may be sticking or the gear may have stripped.
To passing gear
