1968 Under Dash Braces Missing?
Old Nov 28, 2005 | 12:24 AM
68vertible's Avatar
68vertible
Default 1968 Under Dash Braces Missing?
In my 1968 assembly manual, UPC 1, page A 6.5 and A 6.6, there are a group of under dash brace rods shown. I have the dash out of my '68 roadster and there are no such braces in the car. Not only that, but I see no sign of any of the attachment points show in the AM. Are these braces something that were added later or am I actually missing something here? If they are missing, whoever took them out took everything out including all the braces on the tunnel and below the windshield pillar. But I don't even see any indication there was ever any of the bracing there. You'd expect to see empty rivet holes, or spot weld tracks....something!
Old Nov 29, 2005 | 07:30 PM
69monzacpe's Avatar
69monzacpe
Mines a 69 coupe with air, and I saw the same thing. I don't think anyone was inn there since it was built, (Jan 69) so my assumption was that they just didn't get put in. Mine however did have mounting locations for the rods.
Old Nov 29, 2005 | 08:13 PM
kaiserbud's Avatar
kaiserbud
I think those braces are for the verts only
Old Nov 29, 2005 | 08:19 PM
68vertible's Avatar
68vertible
I think you're right about being only on verts. Also, I've been talking with someone who parts these things out on a regular basis and he says that they really didn't start putting them on until mid '69. He said he's never seen a set on a '68 and some early '69's. So, mystery solved. Nobody's been messin' with my baby.
Once again, thanks for the help. This forum is so freakin' cool!
Old Nov 29, 2005 | 08:44 PM
carriljc's Avatar
carriljc
Default My 68 has braces on both...
the driver's side and the passenger's side.
Old Nov 29, 2005 | 09:32 PM
big_G's Avatar
big_G
I have 'em on my late production '68 'vert.....(s.n.>22,000).
Old Nov 30, 2005 | 12:09 AM
68vertible's Avatar
68vertible
Well, now this is getting interesting. There are braces on some 68's so that means it may be a part-year production thing.
If anyone has a chance to take a picture of the center console area where the rods attach to the bracket on the tunnel, that would help me understand exactly where I should be looking for signs mine ever did have this bracket. For now, I can't see anything that would indicate my car ever had rods installed. The AIM is pretty clear where the bracket should be under the A pillar and there are no markings there.
I wouldn't worry about it much except I know the 68 vert had flexing problems to begin with so if possible, I may want to see how tough it would be to retrofit mine with these rods. Discovering that it may have had them originally would mean that any other needed items (backing plates, etc.) may be in place to make a retrofit easier.
Old Nov 30, 2005 | 01:52 AM
RHD '68 L89's Avatar
RHD '68 L89
My 68 has the dash/scuttle braces and the rear chassis braces as well.
Late production (may 68)
Old Nov 30, 2005 | 09:16 AM
Garys 68's Avatar
Garys 68
Early 68, no braces. But I cant swear no one took them out before I got the car.
I also noticed no obvious brace mounting points when I had my dash out.
Gary
Old Nov 30, 2005 | 12:03 PM
R1234's Avatar
R1234
Mines an early car, Nov. 67 and no braces.
Bryan
Old Nov 30, 2005 | 01:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The braces, brackets, and related hardware are definitely there on my '68 convertible. She has an April build date. Check the AIM page to see if it doesn't specify "67" for convertibles.
To 1968 Under Dash Braces Missing?
