Starts On Second Crank.
Old Nov 28, 2005 | 12:02 PM
schi74's Avatar
schi74
Default Starts On Second Crank.
hi, my 1980 will never start on the first crank when its cold. it wil turn, turn and turn. but on the second crank it starts right up. is this a fuel pump problem? thanks.
Old Nov 28, 2005 | 01:50 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I doubt it. Try replacing the ign module first...then let us know what happens. Are there any codes in the computer?
Old Nov 28, 2005 | 01:54 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
computer?
Old Nov 28, 2005 | 02:48 PM
zwede's Avatar
zwede
You need to pump the gas before starting in cold weather. Find how many pumps your engine likes. Some onyl need one, some two or three.
Old Nov 28, 2005 | 03:17 PM
fl_rider's Avatar
fl_rider
Default Three pumps for mine...
But only when its cold.
When she is warm its hands off.
Ah, carburetion..... isn't it wonderful??
Old Nov 28, 2005 | 04:38 PM
stingr69's Avatar
stingr69
Probably the fuel is leaking out of the bowl well plugs while sitting. If you can fire it back up right away from a cold start, your bowls ran dry and the fuel pump was buizy filling it back up while you were cranking.
-Mark.
Old Nov 28, 2005 | 06:01 PM
GaryS's Avatar
GaryS
If you are talking about cold as in after sitting all night or for many hours, then you have what sounds like a normal operation for an old carb equipped car. As others have suggested, the fuel is draining out of the carb and must be refilled by cranking the engine before it will start. OTH, if you are talking about letting is sit for 30 minutes or so, it should start right up. Same thing for some of the fumes you smell in the garage on shutdown. Limited evaporative controls and you get some interesting fuel/oil/exhaust smells in the garage.
After I had a complete and thorough rebuild of my original Holley, the car could now sit for a day or two and still have fuel in the bowls.
Gary
Old Nov 28, 2005 | 07:12 PM
Kalway's Avatar
Kalway
Curious, is he pumping the accelerator a few times before turning the key? When cold I usually press the accelerator about 1 - 5 times, depending on how cold it is. On a really warm day sometimes I don't even have to pump it at all.
Old Nov 28, 2005 | 10:25 PM
randyredleg's Avatar
randyredleg
My '80 does the same thing.Cold where I live is under 60 degrees, but there is a difference in starting at 60 vs 80.I crank her once, then pump twice and she kicks in on the second crank.
Very temperature sensitive. When it's cooler it takes a while for the idle to come down.
Old Nov 29, 2005 | 09:09 AM
TexasYankee's Avatar
TexasYankee
When I bought my Vette recently, the salesmen reminded me about "pumping the gas pedal " prior to starting. It had been a very long time since I owned an "older" ca,r so I actually forgot about doing that.
I belive pressing on the gas prior to starting is like setting the choke(??). The very first car I owned, a late 60's buick, had to be pumped about 5 times on a cold morning to even have a remote chance to start .
Old Nov 29, 2005 | 11:46 AM
rihwoods's Avatar
rihwoods
Yep...cold...one pump,usually....
When runnin in hot weather...sometimes have to depress gas pedal halfway to restart...
Old Nov 29, 2005 | 08:15 PM
vabeachvette's Avatar
vabeachvette
Same by my 73, cold 3 pumps then crank, when she is warm cranks right up without depressing the gas.
Old Nov 29, 2005 | 08:48 PM
71coupe's Avatar
71coupe
Check the EGR valve. Carbon can build up & cause it to stick partially open, causing a lean condition.
Old Nov 30, 2005 | 12:38 PM
C3 4ME's Avatar
C3 4ME
Take the top of the air cleaner off when the car is dead cold after having sit all night. Go inside the car, and pump the gas pedal to the floor once, now go back out and see if the choke plate is closed off. It should be closed completely. If not, your choke needs adjustment. FWIW, on mine I pump it twice to the floor and then start it. The first time sets the choke, and I figure 1 more time to put a little extra gas in the carb. I acutallky tried more than 2 times once, and it flooded the carb. I have a Q-jet carb. Actually after the car has set for a few days or more, even with 2 pumps it still cranks for a couple of seconds before starting. Again though, this is all dead cold only, once it's been started once, it starts right up.
To Starts On Second Crank.
