Carb problem
Old Nov 28, 2005 | 07:50 PM
BARRY L-48's Avatar
BARRY L-48
Default Carb problem
I have an 80 L-48 with a rochester quadrajet and after driving it the idle speed always has to be readjusted,I must kick the gas pedal down a time or two to get it to idle properly.Today when I took her to work,instead of kicking the gas pedal,I removed the air cleaner expecting to find the choke not fully open but it was fully open,it is electric choke,I did purchase a carb rebuild kit for a project this weekend,will rebuilding this eliminate this problem or should I look elsewhere for the problem,I do not know when or if the carb has ever been rebuilt so it can't hurt to do it.Any help would be much appreciated!
Old Dec 3, 2005 | 06:34 PM
BigBlockk's Avatar
BigBlockk
First you need to get the base plate off of it.
In the photo above the well plugs are the four red dots at the top. The plug to the left (accelerator pump well) leaks sometimes as does the fuel inlet plug at the bottom of the picture. It's a good idea to do them all while your doing. These are plugs with soft metal peened into the seams. They plug access holes used for drilling passages when the carburetor was manufactured.
By the way, if you're going to be working on this carburetor you really need one of these.
http://www.ecklers.com/product.asp?p...&dept%5Fid=224
BigBlockk
Later.....
Old Dec 3, 2005 | 06:35 PM
BigBlockk's Avatar
BigBlockk
Sorry, wrong thread.
BigBlockk
Later.....
Old Dec 3, 2005 | 07:20 PM
Kalway's Avatar
Kalway
Shouldn't be too hard to find the electric choke parts. Check summit, they have just about every part of a q-jet you'd ever need.
Old Dec 4, 2005 | 06:56 AM
kb2fzq's Avatar
kb2fzq
If the choke was open, I'd say the electric choke was working fine...sounds to me like you have some sticky linkage...I had that prob with mine when I put it back in service (wired the electric choke)...maybe some carb cleaner, and look to see where it's locking/jamming up, doesn't take much to cause that problem..I ended up loosening the shaft screw to the fast idle just a hair...all better.
Old Dec 4, 2005 | 08:13 PM
plasticchevy's Avatar
plasticchevy
If your not sure if the carb has ever been rebuilt then it probably would be a good idea to do so... The before mentioned rochester rebuild manual is an invaluable tool... The book almost exclusively focuses on the Q-Jet and I really don't think it could be anymore detailed... Well worth the 15-20 bucks when considering the time it will save...
I got mine at Amazon for 11.99
Good luck
Old Dec 5, 2005 | 12:35 PM
Boofers's Avatar
Boofers
One possibility for this problem could be that your primary throttle plate shaft holes in the carb baseplate could be worn. This causes your primary throttle plates to be stuck slightly open because they end up being 'twisted'. The fix for this problem is to have a carb repair guy install bushings in the baseplate to eliminate play in the shaft.
Another possible cause - IF your air cleaner is an aftermarket drop base aircleaner what can happen is bottom of the air cleaner can hold down the top of the accelerator pump lever, causing your throttle to stay open. Look on the bottom of your air cleaner for wear marks.
This may help you figure it out -
The ultimate QJet troubleshooting paper by Lars
Old Dec 5, 2005 | 12:38 PM
Stewart's74's Avatar
Stewart's74
This is what I was going to suggest....might as well start with the easy and free fixes first....
To Carb problem
