need help with converter seal
Old Dec 2, 2005 | 09:52 PM
Vette81Man's Avatar
Vette81Man
Default need help with converter seal
need help with the torque converter seal....keeps leaking and i would like to know what would be the best converter for my 81 vette any help would be good....
thanks vette kid.
Old Dec 2, 2005 | 10:04 PM
Retro78's Avatar
Retro78
The seal is in the transmission end. I do not see why you would need a new converter.
Old Dec 3, 2005 | 06:36 AM
comp's Avatar
comp
more info
Old Dec 3, 2005 | 08:08 AM
marshrat99's Avatar
marshrat99
thanks vette kid.
Since the seal is only a piece of hardened rubber surrounded by a thin metal ring, about any good name seal should work just fine. Just remember to apply a liberal amount of lube all over the seal before reinstalling. Also clean & lube the surface of the converter that inserts thru the seal. The seals are a little tight going back in but just be patient and take your time. Last piece of advise is to be sure that the converter seats all the way back into the tranny. Most of the time, the converter will feel like it "clicks" twice before it is seated properly. Also, if you can run your fingers back behind the converter, it is probably not seated all the way in. Good luck.
Old Dec 5, 2005 | 11:02 AM
Vette81Man's Avatar
Vette81Man
the reason why i ask "what would be the best converter" was because i just might get a new tranny with a shift kit in it....so i was just woundering what would be the best for my new tranny, and i am goni to rebuild my old onw just for a back up....so any info. would be great.
thanks yall vette kid
Old Dec 5, 2005 | 12:16 PM
markdtn's Avatar
markdtn
Stock trans for an 81 is a TH350 with lockup converter I believe. These are notorious for leaking front seals. Probably can't get a "performance" conveter for a TH350 lockup, but I may be wrong. Pretty sure you can convert your current trans to a non-lockup configuration with a different front pump. It's been a while since I did research on these, my recollection is fuzzy. Maybe somebody with recent experience will chime in.
Old Dec 5, 2005 | 01:20 PM
MILO's Avatar
MILO
The reason why it may be still leaking is that there is a groove on the converter where the seal lip sits. Same thing for harmonic balancer leaks, but I know they make a thin ring that you can tap on the balancer to remove the groove. I don't know if the repair exists for converters.
Good Luck.
To need help with converter seal
