I've got a 79, but I assume it is either the same or very simular.
Chrome WS molding - side pieces unscrew, screws maybe under weatherstrip
WS top mold - 2 clips on each end, from the ends pry straight up & the molding will pop out.
T strip chrome - screws on the front, on the back mine had a pop rivet on each side, these have to be drilled out.
WS corner, T-top locator - 4 screws, 2 front & 2 rear. In most cases the WS must be removed to access the front 2. Corner mold may be stuck down with old crud, WS adhesive, black tar like GM goo, etc. Pry carefully from underneath as the moldings are cheap cast items & the edges will break.
be very very careful with the ttop pieces as the bend and deform and then will be a pain in the ace to put back on and a real good way to chip your paint, as i did, not bad though, but something to watch out for. they suck.
The trim on yout t-top roof panels have a rivet holding them on. You will be able to remove the trim until reaching the rivet located on the front inside end. Many painters tape it in place to avoid paint damage on reassembly. Also, if you decide to grind the rivet for trim removal, have a plan for installation. After considering all options, you may decide to leave it in place.
My 69 coupe has 10 clips holding the top WS s/s trip in place. Pry straight up very carefully and evenly across the strip to avoid damage. I assume your 71 is the same. Everything else is the same as advised and as I remember. Don't forget to post your experience for the next guy.
The screws at the WS corner are blocked by the glass, Try to get them with a small flat screw driver on a angle.Little patience they"ll come loose.If your already taking the glass out, not a problem.
