Wire Spice ?
Old Nov 29, 2005 | 08:40 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Wire Spice ?
Has anyone used the type splice where you insert the ends of the wire into a correct sized plastic tube and then tighten down the end collars to make the connection? When I rebuilt my starter harness I used these to replace all three heavy wires that were damaged....having second thoughts now about the "fix" since there is so much juice going thru there........
Old Nov 29, 2005 | 12:28 PM
markdtn's Avatar
markdtn
You can do it that way, but I wouldn't. You will add some resistance to what may be an already marginal cable. Pain in the rear, but I'd change it. You can go to a big truck dealer parts counter and get a 00 cable instead of the stock 1 or 0 gauge cable. Just supply a length and desired ends and they can make or order it.
Old Nov 29, 2005 | 01:26 PM
Boofers's Avatar
Boofers
Butt connectors are fine for low power stuff or areas that are not exposed to the elements.
Old Nov 29, 2005 | 01:30 PM
GATOR454's Avatar
GATOR454
I don't think I would use them for a permanent connection. A properly crimped and shrink wrapped butt connector will give you a more durable connection. With the plastic tube connector I would tend to worry about corrosion and oxidation degrading the connection.
The best thing to do is get one of these:
weather pack connector
Wire the female part of the plug to where all three wires in your harness are good. Then wire the new wires to the male plug. Run the wires to your starter and add the proper ring terminals. I wrap the new harness in heat tape since it passes pretty close to the exhaust manifold. This way replacing the starter is much easier since it allows you to rewire the new starter on the bench and not under the car.
Old Nov 29, 2005 | 01:51 PM
Hvymtlc5's Avatar
Hvymtlc5
sometimes I need a little prodding to do the right thing.........
Old Nov 29, 2005 | 06:17 PM
marshrat99's Avatar
marshrat99
For my money, I only use connectors as a quick fix, meaning until I get time to use soder and shrink wrap. I've tried in the past but over time most connectors has let me down. Good soder and shrink wrap will last virtually forever.
Old Nov 29, 2005 | 09:09 PM
71rdster's Avatar
71rdster
I started with motorcycles, so everything is subject to the elements. I like soldered joints with shrink wrap or electric tape for most repairs. For higherr amp loads, I prefer to replace the wire completely if possible.
Orville
Old Nov 29, 2005 | 09:45 PM
rondo73's Avatar
rondo73
I've used the crimp style connectors . . matter of fact, have one on my starter cable right now but only as a temporary fix. I agree with the other guys and would opt for a more permanent fix.
Old Nov 29, 2005 | 09:53 PM
Bud640's Avatar
Bud640
To Wire Spice ?
