Cold Spark Plug
Old Nov 29, 2005 | 11:45 AM
Tpls 69's Avatar
0Tpls 69
Former Vendor
Default Cold Spark Plug
Need help with a p/n for a colder spark plug. Driving a '69 350/350, and use R35S plugs.
Old Nov 29, 2005 | 12:24 PM
djgrelli's Avatar
djgrelli
The correct AC spark plug for your application should be a R43S plug. I could be wrong but this is right out of my old chilton manual.
Old Nov 29, 2005 | 01:31 PM
big_G's Avatar
big_G
and I wouldn't go any colder, unless you on the juice or running a blower...
Old Nov 30, 2005 | 09:25 AM
Tpls 69's Avatar
0Tpls 69
Former Vendor
I goofed on the spark plug number. You're right it's a R43S plug that I'm using. I'm getting extreme detonation, after installing a new distributor. I've got the timing down to 8 degree's, and have the plugs gapped to .045.
Old Nov 30, 2005 | 12:55 PM
PureSilver's Avatar
PureSilver
Not to ask dumb questions, but did you change your wires? Had this problem with my GMC one-ton van after doing a 'tune-up'. Wires looked fine, but weren't.
Old Nov 30, 2005 | 01:46 PM
pws69's Avatar
pws69
Sounds like that "new" distributor needs some setup - those plugs should be fine. Try Lars' papers on distributors and timing. I wouldn't eliminate the carb/vacuum from the equasion either.
Old Nov 30, 2005 | 05:06 PM
Tpls 69's Avatar
0Tpls 69
Former Vendor
I did change the wires, but I'll check them again. Thanks,
Old Nov 30, 2005 | 05:09 PM
Tpls 69's Avatar
0Tpls 69
Former Vendor
I stayed with the larger springs on the distributor, and I installed a new gasket when the carb was reinstalled. However, I will check out Lars paper. Appreciate the suggestion.
Old Nov 30, 2005 | 10:50 PM
marshrat99's Avatar
marshrat99
Pull and block the vacuum going to the distributor. Timing should'nt be more than 36* at 2500 RPM. If more then need to change the distributor springs or weights. Since most distributors are usually shipped setup on the conservative side, I wouldn't think this to be your problem unless you've adjusted it. However when you ask about a "colder" plug, it makes me think that you're seeing a plug looking like its getting too hot. This would sound like a possible vacuum leak screwing up you air/fuel mixture causing a lean condition.
Old Dec 1, 2005 | 08:41 AM
Tpls 69's Avatar
0Tpls 69
Former Vendor
Thanks I'll try that.I'm also going to re gap my plugs back to .035 from .045 ( as per Lars paper).
Old Dec 1, 2005 | 11:21 AM
pws69's Avatar
pws69
Larger (stiffer) springs cause the advance to come in later which definately could contribute to your problem.
One down...
Old Dec 1, 2005 | 05:08 PM
Tpls 69's Avatar
0Tpls 69
Former Vendor
One down...
Thanks.
Old Dec 1, 2005 | 06:05 PM
dennis's Avatar
dennis
May be a mute point ,but my 70 L-46 uses a R-44. I believe 69 is the same. Lt1 uses a R-43. I actually went the other way with a R-45.
Your timing should be 4 degrees, all else being equal. 1970 uses 8 degrees, but then there's no advance at idle. (Good old TCS system)
To Cold Spark Plug
