HELP! 68 Wiper Problems
Old Dec 1, 2005 | 07:40 PM
Z06forGM's Avatar
Z06forGM
Default HELP! 68 Wiper Problems
Does someone have a wiring diagram for the wiper system on a 68 Corvette ? I have everything hooked up, the wipers work, the over rider works, the vacuum works. The problem I have is the door opens when you turn the key on, ALL THE TIME. There is a solenoid under the dash that has a tan(brn?) wire to it, and when it is connected, the wiper door always opens. When it is disconnected, the door only opens with the bypass under the steering column. Anyone have any ideas ?
Thanks, Gary
Old Dec 1, 2005 | 10:09 PM
68sbShark's Avatar
68sbShark
Had the same problem with my '68. The problem is the park switch in the wiper motor. Auto Zone sells them for about $40 bucks I think. Once I changed the motor, everything was good. If you have any other questions, feel free to PM me....We'll get this thing worked out.
~Rich
Old Dec 2, 2005 | 12:41 PM
Z06forGM's Avatar
Z06forGM
Thanks Rich
The wiper motor and pump is rebuilt, I got another rebuilt unit and the same problem is there. Any other suggestions ? PLEASE ?
Old Dec 2, 2005 | 01:22 PM
68sbShark's Avatar
68sbShark
Sent you an email....We can discuss this off the forum if nobody else chimes in with a solution.
~Rich
Old Dec 2, 2005 | 02:11 PM
cannonfl's Avatar
cannonfl
~Rich
If you two find a solution please post it here. Thanks...
Old Dec 2, 2005 | 02:24 PM
68sbShark's Avatar
68sbShark
Will do.
~Rich
Old Dec 2, 2005 | 07:13 PM
grybdn's Avatar
grybdn
try searching this forum for posts called "Help with wiper door".
I don't know how much the 68's and 70's are alike, but ButchR had a lot of problems, and some sound advice on things to check.
Good luck.
Old Dec 2, 2005 | 07:35 PM
R1234's Avatar
R1234
This is a good site for 68 wiper info. Look in the misc. section.
http://www.corvettefaq.com
http://www.corvettefaq.com/c3/1968Wiper.doc
Old Dec 3, 2005 | 11:36 AM
Z06forGM's Avatar
Z06forGM
Thanks guys, will check it all this weekend!
Old Dec 3, 2005 | 11:44 AM
Cali,68,L-79's Avatar
Cali,68,L-79
http://www.corvette-101.com/registry.htm
To HELP! 68 Wiper Problems
