Started tuning the edelbrock q-jet.(new 1901). Want to run it while I send the original out for R&R. Got a decent jet/rod starting point ala Lars tuning. I now have a problem with cold start/choke.
When the choke is on full during a startup, the engine runs dead rich, smoking, running like crap. The choke seems to be functioning properly. Closes with a pump of the pedal, opens slightly after starting, etc.
If I hold the choke flap open, it idles up to 15-1800 running smooth, no smoke. Once warm everything is fine. What did I screw up with the jet/rod change?
BTW, I put the original jet/rod back, but the problem is still there. It also seems I have the idle adjusted in awfully far to get an idle. don't know if that can be related.
The rod from the devoiced choke coil on the manifold should have a kink in it. Bend the rod so that it is a little longer. This will force the choke blade open some more leaning the mixture. GO SLOW!!! Choke mechanisms can be very sensitive. A little can go a long way.
don't think choke should close completely. sounds like it should have a slight opening when full on. check the specifactions on the carb. also there should be a cold idle adjustment.
Had the same issue on my L-36. I'm using an Edelbrock 1901 also. The Edelbrock needs to use a small block style choke coil. It opens in the other direction. I tried to turn the coil around on the BB stock one but the positive stop doesn't end up in the right place. Lars figured this out for me and the choke coil of the small block works perfect. It's easy to check, warm up the engine, shut it off take the top of the air cleaner off and see if spring pressure holds the choke open or closed.
Warren
Obviously, on start you're trying to run the engine with little or no air..if the butterfly doesn't open a 1/8-1/4 inch after the engine starts, adjust the choke rod so you have that gap when cold and you hit the gas once, it may not be textbook adjusted, but it'll run correctly during warm up..there should be a fast idle screw that ups the idle speed during warm up, linked to the choke spring..once warm and a hit of the gas the choke opens and the fast idle screw disengages and the primary idle screw takes over...your primary idle adjustment shouldn't involve fast idle...IMO
You need to adjust your choke pulloff - it should pull the choke open 1/4" upon startup, but you can set it up anywhere you need it to be. Drop me an e-mail for a specific choke setup procedure: V8FastCars@msn.com
Lars
