Empty Fuel Filter....
Old Dec 4, 2005 | 07:31 PM
blackbeauty74's Avatar
blackbeauty74
Default Empty Fuel Filter....
Most of the time when my 454 gets warm and I let it idle I notice that the fuel filter is almost empty. If i raise the rpm's it fills again. I never gets so low that it stalls, but it hesitates until I give it gas. It only hesitates when Im taking off and barley giving it gas. I also notice that after I park and shut the engine off it will get empty, but when the car cools it will fill again. I have changed the fuel pump, but no change. What do you guys think??
Old Dec 5, 2005 | 10:13 PM
jcswm's Avatar
jcswm
mine kinda did the same thing..... but with a rusty fuel tank....
The rubber fuel line that comes off the bottom of the tank is secured to the frame where it makes a 90 Deg turn & attaches to the steal fuel line along the right frame rail... the rubber hose was kinked and hard as a rock.
I'm guessing the kinked fuel line caused enough of a restriction the pump had trouble overcoming it at low RPM's
Anyway.... I replaced that fuel line & now my filter stay's pretty full & the car runs better at lower RPM's. I'd replace that fuel line First.... UNLESS...... you hear a big Whoosh of air when you take your gas cap off after you've been driving awhile.....
Old Dec 6, 2005 | 08:29 PM
blackbeauty74
Thanks for the info, but what exactly would the big whoosh of air mean?
Old Dec 6, 2005 | 08:32 PM
jcswm's Avatar
jcswm
Blocked tank vent
To Empty Fuel Filter....
