minimum headlight vacuum
Old Dec 5, 2005 | 11:40 PM
gator79's Avatar
gator79
Default minimum headlight vacuum
what is the minimum vacuum needed for the headlights to operate?
Old Dec 6, 2005 | 12:15 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Old Dec 6, 2005 | 06:26 AM
Razorhorn's Avatar
Razorhorn
I just got mine out of the shop. I've always had a winking problem, and I told the shop to take a look at it. They told me I have 14 psi from the 540 ci, and he said I needed 18 psi. he said big-blocks have a problem generating the vacuum pressure needed for these lights. I don't know if I completely buy into that, but the guy has a lot of experience working with Vettes/ As soon as I fix some of the other issues with the car, I'll dive into this one...
Old Dec 6, 2005 | 06:49 AM
Gordonm's Avatar
Gordonm
That is not right at all. First off it is not pressure (psi) It is vacuum. I have run mine on as little as 8 inches and it worked fine. It has nothing to do with BB vs SB. Your cam and motor condition determines what vacuum you have. I am running at 11 inches right now at idle and my headlights work fine. I have rebuilt the system also. It sounds like you have some vacuum leaks and/or some bad seals in the acuaters.
To minimum headlight vacuum
