High Temp Starter
Old Dec 6, 2005 | 12:16 PM
vette24chick's Avatar
vette24chick
Default High Temp Starter
Does anyone have a recommendation for a good high-temp starter?
Old Dec 6, 2005 | 12:51 PM
b71vette's Avatar
b71vette
Default Powermaster manufacturers good ministarters
which are resistant to heat soak. I beleive Jegs and Summit sells them.
http://store.summitracing.com/defaul...h.asp&N=400345
Old Dec 6, 2005 | 07:49 PM
C3 Stroker's Avatar
C3 Stroker
I have the Powermaster XS Torque mini starter (200 ft-lbs.)......4 years so far with no heat problems and am using Hooker Super Comp headers.
Old Dec 6, 2005 | 07:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i would think any hi torque mini starter will accomplish this.
Old Dec 6, 2005 | 08:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The GM BB502 starter is a nice unit.
Old Dec 6, 2005 | 08:26 PM
Gordonm's Avatar
Gordonm
That is what I am using. Never had a hot start problem again
Old Dec 7, 2005 | 07:15 AM
aussiejohn's Avatar
aussiejohn
Default Starters
24chick,
Most standard starter motors run "direct drive" i.e. the pinion gear turns at the same speed as the armature. High compression diesel engines often had trouble with this set-up so the manufacturers fitted a reduction gearset in the unit so that the pinion gear turned at say one third or one quarter of the armature speed, but with THREE or FOUR times the torque. Also, the solenoid that engages the starter is often mounted further away from the exhaust and is therefore less likely to suffer from heat soak.
I have heard that the GM gear reduction starter uses PLASTIC gears rather than steel, and might be best avoided because of this.
Good luck.
Regards from Down Under
aussiejohn
Old Dec 8, 2005 | 09:15 AM
vette24chick
Any recommendations as to where I should get it from?
Old Dec 8, 2005 | 09:24 AM
GDaina's Avatar
GDaina
Yep..Am using that as well on mine
www.paceparts.com ....
To High Temp Starter
