Control arm cross shaft
Old Dec 8, 2005 | 10:58 AM
Jim71Vette's Avatar
Jim71Vette
Default Control arm cross shaft
I finally got these control arms rebuilt and ready to install, but I forgot to note which side of the control arm goes against the frame. One side is flat around the bolt holes, the other is raised. Which side mounts against the frame ?
Old Dec 8, 2005 | 11:30 AM
sly vette's Avatar
sly vette
Flat side.
Old Dec 8, 2005 | 07:16 PM
Jim71Vette's Avatar
Jim71Vette
Default Thanks slyvette
Old Dec 9, 2005 | 11:52 AM
72LS1Vette's Avatar
72LS1Vette
I could have sworn that some months ago someone posted that the raised side went against the frame. I just received my AIM yesterday and the drawing does look like the flat side faces the frame.
I just started loosely assembling the front suspension on my car and now that I have the manual I see that the upper arms are on the wrong sides and the lowers have the wrong side of the shaft against the frame.
This is going to be a long project.
Rick B.
Old Dec 9, 2005 | 12:11 PM
flood's Avatar
flood
digital cameras have their place. I always take pics before I tear something apart
Old Dec 9, 2005 | 01:38 PM
72LS1Vette's Avatar
72LS1Vette
Unfortunately, No. 1 son removed the arms before I could get pictures. I did get pictures of the arms before I removed the shafts to make sure they were put back in correctly with the bushings. Lucky that I found these mistakes before I put the springs in.
Rick B.
Old Dec 9, 2005 | 04:20 PM
Jim71Vette's Avatar
Jim71Vette
So......... is it the flat side against the frame ??
Jim
Old Dec 9, 2005 | 08:30 PM
72LS1Vette's Avatar
72LS1Vette
Jim
I just sent an email to Van Steel to get an answer to the question. I'll post the info as soon as I receive it. I need to know the definitive answer myself before I go and reassemble my front end.
Rick B.
Old Dec 9, 2005 | 09:28 PM
71-Stingray's Avatar
71-Stingray
Mount the flat side towards frame.
This article has photos and explains the procedure.
http://www.corvettefever.com/howto/39038/index.html
Old Dec 10, 2005 | 07:35 PM
72LS1Vette's Avatar
72LS1Vette
That's great info. The article answered a few questions I hadn't asked also.
Rick B.
Old Dec 11, 2005 | 07:01 PM
72LS1Vette's Avatar
72LS1Vette
After reading the article and looking at my lower control arms I'm still not sure which way to orient the cross shaft. Mine do not look exactly like the ones in the article. Here are 2 photos - I reversed the cross bar on one side. Maybe someone who works on Vettes for a living can chime in as to which installation is correct.
Installation 1:
or Installation 2:
Rick B.
Old Dec 11, 2005 | 07:05 PM
big_G's Avatar
big_G
Pic. 2 is the correct way.
Old Dec 11, 2005 | 07:19 PM
72LS1Vette's Avatar
72LS1Vette
Thanks. That's the way I originally installed them. I needed to know for certain before installing the springs. As you can see from the pics I also need to wipe off all the sawdust from my latest woodworking project. I really need more than a one-car garage!
Jim71Vette, if you still aren't sure how to orient the crossbars let me know and I'll take some more pics when I take of the incorrectly installed arm.
Rick B.
Old Dec 12, 2005 | 08:07 PM
Jim71Vette's Avatar
Jim71Vette
Default Above article has set me straight - thanks
To Control arm cross shaft
