Brake Pulls Hard To One Side
Old Dec 8, 2005 | 07:59 PM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Brake Pulls Hard To One Side
Hi, I just got this 1971 coupe off the car carrier and noticed when I get on the brakes it pulls hard to the left, any thoughts?
Old Dec 8, 2005 | 08:09 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Brakes pull
Leaking disc brake caliper on the right side of the car soaking the pads with brake fluid.
Old Dec 8, 2005 | 08:21 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Sounds like a seized up caliper,, the side it pulls to is the good one,,lolll. It can also be like mentionned above, but check for leaks on the ground.
Old Dec 8, 2005 | 08:27 PM
lucky76's Avatar
lucky76
Default bulging brake hose
If there is no leaking fluid then check the right flexible brake hose to the caliper for a bulge in it. I had this problem, pulled to the left and the right hose was the problem. If it is the problem don't forget to replace both sides.
Old Dec 8, 2005 | 08:29 PM
Maymyvetteliveforevr's Avatar
Both front calipers are not apply at the same pressure.
Old Dec 8, 2005 | 10:48 PM
Blue 74's Avatar
Blue 74
Yep, be sure to check/replace the hoses. Mine didn't have a bulge but was rotted on the inside and plugged. Couldn't tell it from the outside but when I unhooked it from the caliper no fluid came out. That was the tell-tale sign. Ran a wire up it and out came gunk.
Old Dec 9, 2005 | 10:07 AM
kb2fzq's Avatar
kb2fzq
Check this thread:
http://forums.corvetteforum.com/show...433&forum_id=3
To Brake Pulls Hard To One Side
