offset trailing arms and width
Old Dec 8, 2005 | 09:13 PM
rastadr's Avatar
rastadr
Default offset trailing arms and width
can anyone confirm that 9.5x17 will be fine with a vbp dual mount rear spring and offset arms. getting a super deal on ttII
cl205's two 17x8 with 4"bs for front and two 17x9.5 with 5"bs on rear for 1100.00 delivered. these are the grey spokes with polished rim. the vender is Jack Jenova at fastlane anyone heard of this person.
Old Dec 8, 2005 | 09:47 PM
bryan717's Avatar
bryan717
I have TTII 9.5X17 in the rear with offset trailing arms on a 73 with a 5 inch backspace. and a 46 1/2 inch long spring from VBandP. 17X8 front with 4inch backspace. I had to remove a little fiberglass on front fenders to for turning clearance, but I have stearoids updated front stearing. You may not have this problem. On the rear the tires stick out of the fenders a little, maybe half an inch. If you want it all tucked in you should research going with a 5.5 inch back space or posibly a little more. If you run in to clearance issues you can use a spacer to bring it back out a little. But I think a 5.5 inch backspace would have fit on mine judging from the room i have. Also ive read that a 18 inch rim verses 17 inch would clear the spring with out having to order the short one as i did. but my spring is the type that mounts to the rear end diff. the 46 1/2 inch length of my spring is measured by wraping the tape measure with the curve, and actualy it looks a little shorter than i actualy needed to clear but i didnt want to have to buy another if it ended up being to long. If i had it to do over again i would get 18s in the rear, and get them 18X9.5 with 5.5 inch back space. but thats just on my car, yours may be different depending on the year i guess. and the type of trailing arms and springs you use.
Old Dec 8, 2005 | 11:23 PM
Z-man's Avatar
Z-man
I've got TTIIs 17X9.5 on rear w/5.5 BS using VBP offset trailing arms. Also using 17X8s in front with VBP transverse leaf spring. You shouldn't have any problems...
Old Dec 9, 2005 | 07:16 AM
Gordonm's Avatar
Gordonm
This might help some. You might not even need offset arms. I'm going to trial fit my 18X10 with 5.5 backspace before putting on offset arms.
http://forums.corvetteforum.com/show...8&forum_id=119
Old Dec 9, 2005 | 02:27 PM
Blue75vette's Avatar
Blue75vette
Be sure to let us know how that trial fitting works out .
Old Dec 9, 2005 | 02:29 PM
Gordonm's Avatar
Gordonm
As soon as I get them I'll post some pictures.
Old Dec 9, 2005 | 03:17 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Cool, what's that target date for delivery?
Old Dec 9, 2005 | 03:45 PM
Bee Jay's Avatar
Bee Jay
I test fit my 18x10.5s and decided that it would be cheaper to buy two more wheels, 18x9.5s, than going the offset trailing arm and narrow spring and no sway bar route. My current wheels are 16x9.5 C4 wheels with 2" spacers. I'm hoping that the 18x9.5s will work fine with 3" spacers. I kept the 18x10.5s, so that when I do all the necessary mods, I will bolt them on. I will post pictures also. I have to order tires next, unless I spend my money on Wilwood brakes. The 18x9.5s arrived last night.
Old Dec 9, 2005 | 04:10 PM
Gordonm's Avatar
Gordonm
Custom wheels. Can be anywhere from 1 week to 5 weeks.
Hoping for the 1 week
Old Dec 9, 2005 | 04:35 PM
PolishMike's Avatar
PolishMike
i have 18x10 boyds on the back and with 285 tires they stick out a tiney bit. about 1/2" maybe a little less. I have the offset arms and vbp kit. 17x8 on the front. Everything looks good.
Old Dec 9, 2005 | 04:58 PM
Gordonm's Avatar
Gordonm
What backspacing are you running.
Old Dec 10, 2005 | 09:29 AM
bahamasair's Avatar
bahamasair
Gordonm where did you get your rims from? Im going to order either the boyd junkyard dogs or the intro pentias. Id like to get some quotes from a couple of different places.
Old Dec 10, 2005 | 03:00 PM
PolishMike's Avatar
PolishMike
Cheapest place i found for junk yard dogs is americas tire believe it or not. They dont have them on there website ( www.tires.com ) but if you go to one of the stores or call them they have a good deal on them.
I run 5 in the back and 4.5 in the front i think.
Old Dec 10, 2005 | 03:14 PM
Gordonm's Avatar
Gordonm
That would explain the 1/2 sticking out. 5.5 backspace seems to keep it all tucked in but real close on the inside. It is either one side or the other. Thanks for the info.
Old Dec 11, 2005 | 09:43 AM
bahamasair's Avatar
bahamasair
Thanks for the link Mike. So Im going to get 18x10 5-120.65 with 5.5" backspacing for the rear. What back spacing and width can I fit on the front. Im thinking 17x9.5 with 4.5 bs but can anyone say if this will rub? The 9.5 might be a little too wide from what Ive seen but Id like to confirm it. I want to get the widest rim and tyre combo on there I can. Also Im looking at 275 40 18s for the rear. Can I step up to 275 45 18? Id like to keep as much rubber as I can. The roads here are pretty crappy. Im also looking for suggestions on the front rubber.
Old Dec 11, 2005 | 12:52 PM
PolishMike's Avatar
PolishMike
on the rear of mine i have 285 35 18s You could go with 40s probably, but u doubt 45s. I think they would stick up to high and rub the fender flare area, im not sure though, so wait until someone either confirms or denies that.
From what i read the front is about 8" wide is a good size for the front ones. More then that and you'll probably end up having to notch out the fenders.
I dont remember if i got 4 or 4.5 on the front.
Old Dec 11, 2005 | 10:48 PM
bahamasair's Avatar
bahamasair
Thanks Mike. Anyone else running anything wider than a 17x8" on the front?
To offset trailing arms and width
Old Dec 12, 2005 | 11:52 AM
shafrs3's Avatar
shafrs3
I've got '86 8.5 x 16" with 255/50-16. Just a little rubbing of the frame behind the lower A arm.
Old Dec 12, 2005 | 07:31 PM
bahamasair's Avatar
bahamasair
Ok it looks like Ill be going with 17x8" for the front. can anyone tell me what back spacing they are using on the front?
TIA
Old Dec 12, 2005 | 08:33 PM
Gordonm's Avatar
Gordonm
17X8 with 4 inch backspacing works very well.
