Frame came off today!!!!!
Old Dec 11, 2005 | 02:03 AM
BlackRocket's Avatar
BlackRocket
Default Frame came off today!!!!!
I got the frame off my "basket case" '69 today. A little/lot of dissapointment though. I have bought 4-cars off the internet and have had problems with each one. This one has a couple of good tears in the fiberglass; under the passenger seat and in the transmission tunnel. Major glass work needed. Also, I found the frame to be rot-free, but was sectioned just in-front of the transmission crossmember.
By the way, the scaffolding and electric hoist I built worked great.
Old Dec 11, 2005 | 02:11 AM
Jclgodale3's Avatar
Jclgodale3
Good job and looks like a clean lift! Even left the rear exhaust panel in place after all!. "THE FUN IS JUST BEGINNING"!
Old Dec 11, 2005 | 07:00 AM
GDaina's Avatar
GDaina
I wouldn't worry about the frame repair as long as the welds are solid and the frame is to specs...good time to measure and determine if frame is square or not.
Old Dec 11, 2005 | 01:00 PM
BlackRocket
I was planning on cleaning-up this frame with the Eastwood metal prep kit and the long spray wand. But after adding-up all the cost I will be 4-5,000 into this frame alone; (I was planning on getting the VB&P transverse suspension kit, the Steeroids rack, and offset trailing arms). If I can get $2,000 for this frame as a roller I'm getting close to what a complete SRIII frame would run.
Old Dec 11, 2005 | 01:56 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Is that scaffolding all wood? Other than the brackets at the top of course?
-Chris
edit: Upon further looking at the picture the answer has become obvious I think. What size are the side and top beams?
Old Dec 11, 2005 | 02:01 PM
Star79's Avatar
Star79
That's cool, I am planning on making a frame like that out of some leftover warehouse shelving frames (metal box section 3" x 5"). Yours looks like it's made out of wood, is that possible??
Old Dec 11, 2005 | 04:22 PM
BlackRocket
Yep, it's wood; 4x6" beams....cost about $150 for everything and I can assemble/disassemble in about 15 minutes! I was going to use metal, but too many $$$ for a 2xuse item. It seemed that the body is not all that heavy even with the doors on. I forgot to disconnect the parking brake U-shaped harness under the car and almost ripped another hole in her!
Old Dec 11, 2005 | 04:42 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Nice lift and support frame. I'm getting ready to lift my body as well, just need the straps and hoist. I see you strapped the front end, do you see it was necessary? Did you place the body on anything?
Old Dec 11, 2005 | 09:57 PM
LemansBlue68's Avatar
LemansBlue68
Reproduction frame sections are available if you don't think you can make the sectioned area look respectable again. A good welder can weld in the repair section, grind the welds flush and you'd never know it was repaired. I wouldn't sweat the glass repairs either...piece of cake and easily concealed. The previous owner of my '68 apparently had an off road experience with my car and cracked the toe board area. I repaired it by glassing the floors in the cracked area from inside with fiberglass mat and filled the outside with long strand filler. The inside repair is concealed by the carpet and the outside is blacked out and covered by the splash shield. The repair is also as solid as any other area of the car. Fiberglass cracks are part of Corvette life.
Old Dec 11, 2005 | 10:04 PM
BlackRocket
I found that the front end was sagging and after I put the rope on it felt much better. Just placed a loop and shanked the rope up tight. I also built a "cartfrom hell" so to speak...made it out of 1.5" square tubing and 6 castered wheels. I'll post a picture of it when I gat a chance.
B-R
Old Dec 11, 2005 | 11:35 PM
gator79's Avatar
gator79
what capacity is your electric hoist? any idea what the body weighs?
Old Dec 12, 2005 | 12:55 AM
Jclgodale3's Avatar
Jclgodale3
looks like the 650/1300 pounder from Harbor Freight
Old Dec 12, 2005 | 10:38 AM
68/70Vette's Avatar
68/70Vette
From previous posts, I'd been led to believe that the doors were not strong enough to support the rear of a Convertible body if you lifted the body. Until now the few pictures on this forum that I've seen showing a Convertible body being lifted, have shown the doors removed with a bracket/brace attaching the hindge mounts to the striker. Your picture says that you can lift a Convertible body with the rear portion supported by the doors only. Interesting. Good to know.
Old Dec 12, 2005 | 12:40 PM
GDaina's Avatar
GDaina
lifted my body with the doors attached...doors provide necessary support.
Old Dec 12, 2005 | 01:08 PM
Maine Vette's Avatar
Maine Vette
Looking good so far!
I know what you mean about the nose sagging, I found the same thing. I didn't dare leave the nose unsupported, I was scared I would crack the fiberglass.
I took my body off with an engine hoist, I'll definitely be building a similar frame to put it back on. The engine hoist worked, but it was rough.
Old Dec 12, 2005 | 01:10 PM
comp's Avatar
comp
Old Dec 14, 2005 | 01:37 AM
BlackRocket
Yep, the hoist is a Harbor Freight 1,300#. I was able to do everything by myself with this set-up! That's why you see the ladder on the left-side....prevented body from swinging in the wind!!!
To Frame came off today!!!!!
Old Dec 14, 2005 | 09:44 AM
1bumprfan's Avatar
1bumprfan
GeeZ-US! Good for you. I have been looking at this job for my 73. Even bought the winch... Good for you.
Old Dec 14, 2005 | 09:53 AM
jester4's Avatar
jester4
Do you think that with this set-up, you could leave the body suspended for the length of the restoration? The reason I ask is that I would like to do the same thing as you, but leave the body in the air and put the frame underneath. I have a 2 car garage, and would like to be able to use the 2nd side for a car that actually goes vrooom......
Old Dec 14, 2005 | 07:59 PM
redwingvette's Avatar
redwingvette
Lokks alot like what I have done. Only I used come-a-longs. One inthe front and one for the lift straps. I didn't like the straps pulling in on the door skins so I cut a 2X4 and ran it out across the doors to push the straps out and that seem to reduce the stress on the doors.
