383 Holley Question
Old Dec 12, 2005 | 08:55 PM
Phil Zell's Avatar
Phil Zell
Default 383 Holley Question
Anybody running a 750 Vac secondarie Holley on their 383, I want to know what size jets to start with.
9.7/1 pistons , 64cc iron heads 2.02/1.6 041 heads, 268 HE cam, 2500 stall converter, headers
Thanks in advance
Old Dec 12, 2005 | 09:33 PM
C3 Stroker's Avatar
C3 Stroker
Thanks in advance
Since all engines are tuned individually for best performance, I would start with the stock jetting (with a Holley or any carb) before changing anything.....then make your adjustments, leaner or richer as needed.
Old Dec 12, 2005 | 10:59 PM
Highhat's Avatar
Highhat
I agree. You can look up the stock jetting numbers on the Holley website.
Old Dec 13, 2005 | 07:20 AM
gerry72's Avatar
gerry72
IIRC, the factory jetting for the 3310 is a 72 primary and the secondary uses a metering plate that translates into 78 jets.
Out of the box metering will be very close for most applications. You might experience a slight hesitation in your part-throttle transitions and maybe some light surging. You can address this in the primary jet by going up two jet sizes. If you want to work the secondary metering, you'll have to spend the 40 bucks for the secondary plate to block conversion kit, but I doubt you'll need to.
One area that you will have to address is the secondary spring. The factory spring is far too stiff. Spend the six bucks for the spring kit and tune your secondary opening. You'll want to start with the lightest spring. If you feel a bog on full throttle, put the next heaviest spring in and go from there. I really doubt that you'll be able to get past the 2nd lightest spring.
It's not uncommon for the 3310 to have a fat idle depending on the cam overlap. You have to pay attention to the primary throttle opening to ensure you don't expose the idle transfer slots. Most of the time you can tune the idle with a little more secondary throttle opening. You might also have to restrict the idle fuel channel restrictors with a couple of pieces of .015 to .020 wire (the web has info on where to place the wires).
With a 3310, you will almost never have to fiddle with the pump cam or shooters. You may have to adjust the pump lever a bit but leave the cam and shooters alone.
The 3310 is a pretty good out of the box carb with the exception of the secondary spring. Leave it alone until you clearly identify what it needs to run better on your car.
Old Dec 13, 2005 | 07:28 AM
gator79's Avatar
gator79
I am running a 770 avenger on my 383 with stock jetting. it does verry well.
To 383 Holley Question
