454 Buildup Options
Old Dec 14, 2005 | 09:38 PM
Maine Vette's Avatar
Maine Vette
Default 454 Buildup Options
A while back someone posted a link to a website with dozens of buildups on 350's as well at the dyno results for each option. Is there anything similar out there for 454's?
I'll be starting with a stock 454 from a 73 vette and want to do a mild to moderate buildup. What kind of numbers have others gotten from similar buildups on their motors?
Old Dec 14, 2005 | 10:55 PM
BigBlockk's Avatar
BigBlockk
Go here. Lotsa good stuff.
http://www.corvetteforum.net/c3/zwed...s_overview.htm
BigBlockk
Later.....
Old Dec 15, 2005 | 11:27 AM
pauvil's Avatar
pauvil
All depends on the bucks you have. I build 500 horses for 500 bucks doing my own machine work and stock iron heads.
Old Dec 15, 2005 | 11:30 AM
71redskin's Avatar
71redskin
thanx for the link big block, thats just what i needed to see as reference point to start my mods on my LS5... u da man!
Old Dec 15, 2005 | 11:55 AM
shafrs3's Avatar
shafrs3
BigBlockk
Later.....
Have you compared the ports on the Torker II with the stock dual plane? The Torker II's ports looked small to me. I know this is supposed to promote good low end and mid-range, but my experience with this manifold has shown me that it sure runs out of steam by about 5000 RPM (on a 496) and has lead me to believe it would be better suited as a towing manifold for medium sized big blocks (454-502) and a solid mid-range manifold for the smaller big blocks (396-427). Don't get me wrong, I love Edelbrock equipment, but the advertised operating RPM band of 2500-7500 seems awfully high to me.
Old Dec 15, 2005 | 12:50 PM
Maine Vette
Thanks for the link!
Have you had it out to the strip yet? What kind of ET's are you getting?
There's always lot's of talk here about building up 350's and 383's, but I don't see nearly as many threads about building 454's. Too bad.
Old Dec 15, 2005 | 01:34 PM
Gage's Avatar
Gage
That's because most people have Small Blocks, including here on the forum. Also, you have to buildup a SB or it is no fun to drive, especially if is 71 or newer whereas BB cars are a blast to drive and have more power bone stock than most of us can use on the street without hurting ourselves, so alot of guys don't build them up. My bone stock 69 L36 427 was more than enough power to have fun with, and I could outrun most cars on the street. But with my 72 L48 car, I am afraid to race the high school kids with the mustangs...that is why the 468 will be going in this Spring!!!
Old Dec 15, 2005 | 02:21 PM
BigBlockk's Avatar
BigBlockk
I wish that was my car. The car and website belong to forum member zwede. I don't know if he ever took it to the track. Beautifull car.
BigBlockk
Later.....
Old Dec 15, 2005 | 02:43 PM
Razorhorn's Avatar
Razorhorn
I was thinking of zwede before I realized that was his link. I'll go down stairs and rattle his cage...
Old Dec 15, 2005 | 03:52 PM
zwede's Avatar
zwede
Alright Tom, back to work!
I don't go to dragstrips much. I did take it last year, though. At the time I had a busted fuel pressure regulator and it was running lean. I raced on my regular street tires with a full exhaust and it ran a high 12. I'm thinking with the exhaust cutouts open and a functioning regulator it should do a mid 12, still on regular tires.
Old Dec 15, 2005 | 06:04 PM
BigBlockk's Avatar
BigBlockk
By the way zwede, is that a factory color? If so, what number? Beautifull car!
BigBlockk
Later.....
Old Dec 15, 2005 | 07:10 PM
Maine Vette
Yeah, I realize there are fewer big blocks out there and it makes sense there will be fewer posts about building them up, I'm just trying to solicit some ideas is all...
The stock specs on my '73 motor are 275 HP / 380 Ft-Lb. I'm aiming to move both those numbers into the mid 400 to 500 range while still keeping the car very streetable. I'll be doing most of my driving around town and on country back roads but I still want to be able to smoke a ricer now and then. I just wanted to be sure this was a realistic goal.
The plan is new heads, cam, carb and intake with headers and dual exhaust out the back. I may work on getting the compression up a bit, it's a whopping 8.5:1 from the factory. I'd prefer not to get into the bottom (engine runs good right now).... Ideas?
Old Dec 15, 2005 | 07:19 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
There were a lot more BB guys around in years past, Les, Mountainmotor, Flareside, Bence, Chuck Harmon, Bob Turner, Sir TriPower, Lasse etc
You can check out my build here:
http://temp.corvetteforum.net/c3/197...y/index4.shtml
and here: http://temp.corvetteforum.net/c3/the...t/index9.shtml
Old Dec 15, 2005 | 07:49 PM
Gage's Avatar
Gage
I hear ya...My 468 has 73 heads, but I'd like to go alum route as well. Actually the stock comp in 73 was closer to 8:1 thanks to the open chamber heads, but they flowed decent to actually increase the hp slightly so you know they flow well if the comp dropped 1/2 pt but hp increased. The torque is actually the same as 72, they just rated it at a lower rpm I think to get the insurance and emissions police off their back. Lots of potential to unlock. Have fun, keep us up to date!
Old Dec 15, 2005 | 08:04 PM
zwede's Avatar
zwede
BigBlockk
Later.....
Thanks! It's Torch Red from a 1997 Corvette. The Paintcode is #70.
Old Dec 15, 2005 | 08:34 PM
Maine Vette
Some good info in there , thanks!
Old Dec 15, 2005 | 09:24 PM
vetteaddic's Avatar
vetteaddic
You know your compression is 8:5.1 now,
find out what your stock heads cc is somebody here may know,then onceyou know that get some aluminum heads with a lower cc to bring up your compression,on the cam get something with 244@.50 duration 556 lift,that should get close to 500hp and plenty steetable.
Old Dec 15, 2005 | 09:28 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Hey Markus......
Ready to go back to track soon??? Wanna borrow some slicks?
Zwede's car does run deep into the 12's in "pure, drive in 150 miles and pull to the line" street trim. Literally pull up and start banging gears!
Now when we get a "real" cam to replace that "healthy" one.....we're going to have some fun!
Hey, you coming down to help with Nicks next dyno day?
JIM
Old Dec 15, 2005 | 10:10 PM
zwede's Avatar
zwede
Jim, starting to get an itch to do something. Drag strip, road course... Car is getting spoiled and needs to be put in its place.
Got new valvesprings coming in any day now. Can you believe I've been running on springs that were 120/330 back when they were new 40K miles ago??? Going to 155/360 with Ti retainers.
Yep, planning to go with Nick for the next dyno day running my smart *** mouth.
To 454 Buildup Options
