How do you replace the speedo needle?
Old Dec 16, 2005 | 12:28 AM
seventyeightcorvette's Avatar
Default How do you replace the speedo needle?
I had my cluster apart the other day and broke my speedo needle (man that thing is thin!). Does it simply pull off from the front or is there something that you have to remove from the back of the speedometer?
Thanks in advance.
Old Dec 16, 2005 | 01:08 AM
HIELP! I need to know this before I rip it apart again.
Thanks.
Old Dec 16, 2005 | 10:58 AM
You've got to be kidding me! No one here know's how to do this?
HELP!
Old Dec 16, 2005 | 11:14 AM
Crash80's Avatar
Crash80
Try and contact these guys. Maybe they can give you a clue.
http://www.redlinegaugeworks.com/
Old Dec 16, 2005 | 01:39 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I can't answer about the speedo, but when I was cleaning my guages, I broke the needle on the fuel guage. I gently pulled it straight out from the face. Then I superglued the needle back together and pushed it back onto the post. Can't even tell I broke it.
Old Dec 16, 2005 | 01:40 PM
big_G's Avatar
big_G
It pulls straight off, sometimes not so easily!
Old Dec 16, 2005 | 02:42 PM
GTR1999's Avatar
GTR1999
Like G said, grip it but don't flex it or you'll wreck the shaft. A little pressure and it should come off. Same to install. Be careful not to get anything on the face of the speedo,like WD40 or it will remove the silk screening.
Gary
Old Dec 16, 2005 | 05:27 PM
Thanks all!
Old Dec 16, 2005 | 09:03 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I find that the needles go on and off better if you twist them slightly as you push or pull them on or off. I bought 2 spare tachs to learn how to do this best before working on my "good" one. Make sure you stop the needle against the stop with the needle set at 0.
Old Dec 16, 2005 | 09:35 PM
Kilroy1024's Avatar
Kilroy1024
There was a pic of a tool posted on a while back but I was unable to locate the thread.
It was like a feeler gauge with the last 1/2" bent and grooved.
Slide it under the pointer and pul straight up.
To How do you replace the speedo needle?
