distributor stupid question
Old Dec 20, 2005 | 02:16 PM
driver68's Avatar
driver68
Default distributor stupid question
sorry for this really stupid question, but i want to check the dwell on my points dist.
The primary wire that the dwell meter connects to, is this the wire coming out of the bottom of the dist that connects to the negative terminal on the coil? this is the only wire coming out of my dis.
('72 coupe that i'm having lots of fun with, just purchased last mo.)
Old Dec 20, 2005 | 02:19 PM
lars's Avatar
lars
Yes, the dwell meter "+" wire connects to the wire going from the coil "-" side to the distributor. The dwell meter "-" wire connects to ground.
Old Dec 20, 2005 | 02:25 PM
kb2fzq's Avatar
kb2fzq
Man, I had to think about that question...I haven't used a dwell meter in (literally) 3 decades...
Old Dec 20, 2005 | 02:40 PM
driver68's Avatar
driver68
Ya, i've always had an HEI, but this came with the original dist, so decided to keep it on. ... only wish Lars was around to rebuild/tune my carb!!
Old Dec 20, 2005 | 03:04 PM
kb2fzq's Avatar
kb2fzq
I think if you pay for a round trip plane ticket, free room and board and free beers...he might get around to British Columbia..
Old Dec 20, 2005 | 11:01 PM
driver68's Avatar
driver68
that would be an awfully expensive carb
Old Dec 21, 2005 | 11:29 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I can tell you a trick from my very FIRST years as a GM tech - when all cars had points.
Using the 1/4 inch allen, turn the screw in the points CLOCKWISE with the motor at idle. Turn clockwise until the motor misfires, or stalls whichever comes first.
Then go COUNTERCLOCKWISE exactly 1/2 turn and you will be at perfect 30* dwell.
Compare it against your dwell meter if you want but it works!
Old Dec 28, 2005 | 06:46 PM
rthawk1's Avatar
rthawk1
I would love to set my dwell in this fashion, however the previous owner installed a Mallory distributer with dual points. The car runs fine, but the dwell is 33 and not 30. Any ideas on how to lower the dwell without having to take the distributer cap off and play games on the inside?
rt
Old Dec 28, 2005 | 07:14 PM
lars's Avatar
lars
rt -
Your dwell is perfect - don't change a thing.
A Mallory Dual Point distributor has (obviously) two sets of points. You have to disconnect or disable each set, and then set the dwell on the opposite set. The dwell on each set is 26 degrees. When both sets are set to 26 independently and then run together, dwell of a dual point will be 33 to 34 degrees. So your dwell is exactly what it should be - don't touch it!
Old Dec 29, 2005 | 11:11 AM
rthawk1's Avatar
rthawk1
Default thanks
Lars,
I appreciate your input. I found the Mallory tech web site last night and they confirmed from questions asked and answered to leave well enough alone. 33 degress is correct for that distributor, but the tech responder said in several responses to set the points at .022.
I have read many of your posts and your knowledge is much appreciated. I spent the day yesterday working on resetting the passengar car window. It is all fun!
rt
Old Dec 29, 2005 | 12:30 PM
lars's Avatar
lars
rt -
He's saying the same thing. You can set the points to .022 gap, and that will produce 26 degrees dwell. Setting the points with a dwell meter is more accurate, since it eliminates the variable of "feel" of the feeler gauge drag through the open points. But don't confuse point gap with point dwell, as the two numbers are not the same.
Note also, for others reading this, that on a stock single-point system, a .022" gap will not produce the correct dwell. On a single-point system, a gap of .016" will give you dwell of about 30 degrees.
To distributor stupid question
