hyper sensitive steering?
Old Dec 22, 2005 | 03:35 AM
johnnybrewmeister's Avatar
johnnybrewmeister
Default hyper sensitive steering?
My '73 vert has always been a bit overly sensitive to bumps in the road and counter steering (at least for the 6 years that I've owned it). The normal "slop" in the steering wheel while driving is no problem. But whenever I hit a rut in the road, or drive over some other abnormality, my vette seems to just about jump in the wrong direction! Is this just what a 30 year old car is all about, and others live with it? Has newer technology found a way to fix/compensate for this? Or is there some rubber bushings in the steering/suspension that are seriously warn and could cause this?
It is bad enough that it almost takes some of the fun out of driving my baby. Any thoughts? I'm a weekend warrior when it comes to mechanic work, but clueless when it comes to this subsystem.
Thanks for any info.
Old Dec 22, 2005 | 06:03 AM
gerry72's Avatar
gerry72
It should go without saying that what you're experiencing is abnormal and is well outside the engineering of a serviceable suspension and steering system.
If you do not have the knowledge and the ability to do this yourself, you need to get the car to a suspension, or better -a Corvette specialist.
It could be worn components (which ones is where experience and knowledge pay off) or something as simple as a bad alignment.
If you want to approach the diagnostics outside of a Corvette specialist, I suggest you take the car to a reputable alignment shop (not like Brake Check who, for the most part, uses McDonald's and Pep Boys washouts). That way you can at least start with their inspection and if nothing is too worn, a good alignment. That may fix your issue. If the car can't be aligned, they'll tell you why and you go on from there.
No one here can tell you what's causing your car to do this. It could be anything from a low tire to a broken and bent frame.
Old Dec 22, 2005 | 12:10 PM
johnnybrewmeister
Thanks for the info.
I don't mind the teardown and replacing components, just don't know what pieces to start looking at.
The tires appear to be fine - balanced, always full, no irregular wear patterns. An alignment is easy enough, and probably a good start.
Old Dec 22, 2005 | 12:36 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Wide stiff tires, manual steering, worn power steering valve all contribute to the rut following you describe. Technically it's called Tramlining.
All cars do it to some degree, some things, like wide tires, make it more apparent.
Good solid power steering helps a lot by swamping out the feedback...
Old Dec 22, 2005 | 12:47 PM
big_G's Avatar
big_G
"What gerry72 said"
Old Dec 22, 2005 | 01:01 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by johnnybrewmeister
My '73 vert has always been a bit overly sensitive to bumps in the road and counter steering (at least for the 6 years that I've owned it). The normal "slop" in the steering wheel while driving is no problem. But whenever I hit a rut in the road, or drive over some other abnormality, my vette seems to just about jump in the wrong direction! ...
John…
I agree with Gerry and big_G.... But if you wait long enough, folks here will have you change every front end component as well as a few in the rear, at least once. Get a very reputable shop to perform an alignment and they will either perform the alignment and solve your problem or they will give you a list of those components that need replacement. With this list, you will know what you can do yourself and what you need to farm out if anything.
If you're not sure of who to take it to, look for a shop that specializes in straightening frames. They can either do it themselves or will send you to a shop that they trust. Opinions on alignment shops are very often like opinions on fast food, but these folks stake their professional reputation on the quality of the work.
GUSTO
Old Dec 22, 2005 | 01:03 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
some alignment shops like to set the toe at 0 to minimize tire wear when you really need to have some toe in. Starting at 0 will give a little toe out when at speed which can cause a very twitchy feeling.
Make sure everything is tight and have the alignment shop give you the amount of toe in in the spec and maybe just a little more. The front tires may wear a little more but its more important to have a feel you are comfortable with. Tires for our cars are cheap.
Old Dec 22, 2005 | 01:09 PM
jdmick's Avatar
jdmick
Make sure the shocks are OK too.
Old Dec 22, 2005 | 01:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i replaced the entire front end and then went to the Steeroids set up .....one of the best moves i ever made....
Old Dec 22, 2005 | 10:08 PM
David Ey's Avatar
David Ey
Complete (less springs) front end rebuild and my '78 seems to be really quick steering.....I mean really quick. Not loose at all. Is this normal? I do have 255's on the front.
Old Dec 23, 2005 | 09:20 AM
gerry72's Avatar
gerry72
Normal depends on how you define "quick." If quick means darty or twitchy, then, no, that's not normal in the mainstream definition. If quick means the car instantly responds to steering input, then, yes, that could be normal. Everyone has a different definition when it comes to vague terms like quick and normal.
If you feel the car isn't normal, then I suggest you take the car to a good alignment shop(a different one than the one that did your current alignment) and have it checked.
Old Dec 23, 2005 | 10:16 AM
jdp6000's Avatar
jdp6000
I call it walking. Mine did it. You never knew where you would end up after hitting a bump or dip in the road. It turned out being my shocks. Easy to check...when you push down over each fender. Does it bounce? Or just spring up? It should not bounce..not at all. Any sweat on the shock where the two pieces join? If there is the seals are gone.
Jim
Old Dec 23, 2005 | 10:20 AM
David Ey's Avatar
David Ey
I would describe it as responsive and very controlable. I wondered if the ratio was closer than other GM cars and trucks. May be because the driver is slightly closer to the wheel centers than what I am used to. I guess if I were directly above the wheels I would think it was much quicker. Thanks Gerry....and JD
To hyper sensitive steering?
