Arghhhh, I took a gamble and bought a "383" short block off Ebay. When I got it, I noticed that the pistons are TRW forged .060 over (not a 383!). The rest of the rotating assmebly is forged, and worth more than I paid for the short block but I'm seeking experience with over bores.
Can a .060 block still be cooled, or am I setting my self up for recurring head aches? I was planning on running AFR 195 heads with an Air Gap RPM intake and a 230ish duration cam with .500ish lift shooting for around 10:1 compression. Should I just canibalize the internals and start with a new block, or will this 010 block still cut it? Thanks for any advice/war stories.
Jim
My combo is just about as you are contemplating.......
388 cu. in. (.060 over)
AFR 195's, competition ported
RPM Air Gap
10.8 compression
230 @ .050, .617 lift (w/1.65 rockers) Comp Cams hyd. roller 286HR
This works well for me with no overheating problems.....170 on hot days using 3300 cfm electric fan. Idles at 850 rpm, good power to 6500 rpm. ....high 11's with 4.11 gear.
C3 Stoker,
If you're in the 11's, you must be pushing 500+hp. I was going witht the AFR's because they are CNC ported. How much additional work did you do on your heads? I've got 3.73 gears and I'm planning on running a TKO 600 on my '69, so I need good torque 2-4000 rpm, so I'm going with a little less lift.
A friend that "has a buddy at a machine shop" said that when boring to .060, they always tap the back of the passenger side head and run a cooling line from the gooseneck to the tap that helps cooling dramatically. Anyone familiar with this surgery?
C3 Stoker,
jim
Actually, it's less than 500 hp at the crank (I believe).....it dynoed at 373 rear wheel hp. and 452 rear wheel torque. The heads are straight from the AFR catalog with the addition of titanium retainers and upgraded valve springs, no additional work. The cam's lift does not affect bottom to midrange torque....it's duration does; 230 @ .050 is mild for a 383 (or 388) and most hyd. roller cams in this range have well over .500 lift. Mine has .560 if you use 1.5 rockers. They also produce more power than a similar duration flat tappet hydraulic, and idle smoother. A 2500 RPM converter works well with this cam and yields GOBS of low end torque.........hyd. rollers cost more, but worth consideration for the power increase.
