Removing the whole nose
Old Dec 23, 2005 | 02:31 PM
napahead's Avatar
napahead
Default Removing the whole nose
Okay what needs to be done to take this nose off , let me hear about it before i decide weither to do it
Old Dec 23, 2005 | 02:51 PM
The Ram's Avatar
The Ram
onwhat?
Old Dec 23, 2005 | 02:58 PM
napahead's Avatar
napahead
my 76 vette from the door to door
Old Dec 23, 2005 | 03:01 PM
The Ram's Avatar
The Ram
2-3 guys, lots of beer and patience...you will need some steady hands...i dont remember exactly what size wrenches and such from when i took my 80 front end off...but you gotta be extremely safe or CRACK! ....good luck!
Old Dec 23, 2005 | 04:10 PM
vetteboy1976kr's Avatar
vetteboy1976kr
Are you deciding to repair the old front end or replace it with a new one?
Its not that bad to take off. A helper would be nice but I removed it myself. Take the doors off and slide a good putty knife at the top between the glued area that the front end is bonded to the cowl (just in front of doors). Hit the knife with a hammer downward so that the glue splits apart. You may run into a few spots where an old serrated steak knife can help by using it to "saw" the glue. Use the knife at the middle where the fender forms an angle. Remember: you only want to seperate the front end from the cowl, so take you time and ONLY split the glue. A heat gun can help, but I didn't use one. The rest of the removal is mechanical (nose support rod, radiator support). PM me if you have any other questions.
Old Dec 24, 2005 | 01:02 AM
napahead's Avatar
napahead
thats it then just pick it up and put it to the side
Old Dec 24, 2005 | 01:05 AM
lowbuck72's Avatar
lowbuck72
A $40 heat gun will melt the bonding adhesive
Old Dec 25, 2005 | 04:13 PM
napahead's Avatar
napahead
thanks for the info people now i just need to decide weither to do it or not
Old Dec 25, 2005 | 06:41 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
How bad is your nose now?
Old Dec 25, 2005 | 10:04 PM
The Ram's Avatar
The Ram
ill be taking the nose off of my 80 while it sits in my garage getting the front suspension redone and the nitrous motor dropped in...so i will be doing this endeavor once again!
Old Dec 25, 2005 | 10:15 PM
napahead's Avatar
napahead
it's got a few good size cracks in it and the upper right connor is all messed up
dennis's Avatar
dennis
[QUOTE=vetteboy1976kr]
Its not that bad to take off. A helper would be nice but I removed it myself. Take the doors off and slide a good putty knife at the top between the glued area that the front end is bonded to the cowl (just in front of doors). Hit the knife with a hammer downward so that the glue splits apart. You may run into a few spots where an old serrated steak knife can help by using it to "saw" the glue. Use the knife at the middle where the fender forms an angle. Remember: you only want to seperate the front end from the cowl, so take you time and ONLY split the glue. QUOTE]
I see how a knive through the glue at the side cowl door pillar works, but how do you get to the glue at the front of the side cowl?
Old Dec 25, 2005 | 11:01 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I wonder if you could do the piano wire trick like window replacment techs do for around the cowl or are the angle too goofy for it?
Old Dec 25, 2005 | 11:51 PM
comp's Avatar
comp
Old Dec 26, 2005 | 06:24 PM
vetteboy1976kr
Dennis: For the front side of the cowl you have to reach inside the engine compartment to do it. The top inside is the toughest part to do, but if you do the back side of the cowl (near doors), the top (near winshield), and the bottom (under the car), you can pretty much yank it off without breaking anything. This is where the heat gun would help. The piano wire may have difficulty cutting the glue, but with the heat gun it might do it. Worth a shot if you have some to try.
Old Dec 26, 2005 | 06:57 PM
dennis's Avatar
dennis
Old Dec 26, 2005 | 08:11 PM
lowbuck72's Avatar
lowbuck72
Since you'll be trashing the front end anyway, you can cut away pieces to get access to the bonded areas. Before you throw the old pieces away, save them to use as templates for marking the holes on the new front end for the emblems.
To Removing the whole nose
