lower steering column bearing question
Old Dec 26, 2005 | 12:14 PM
68/BB's Avatar
68/BB
Default lower steering column bearing question
anyone ever remove and replace a lower bearing in a '68 steering column? how do you get that little devil out of there?
Old Dec 26, 2005 | 03:16 PM
sly vette's Avatar
sly vette
With column out of car, remove rag joint flange. Then remove the pinch sleeve. Now remove the retaining clip from around the retainer, and remove the retainer, and the spring. You should now have access to the bearing and nylon and/or teflon bearing holder. Clean the shaft with emery cloth spray with some PB Blaster, and try to pry the bearing GENTLY up and off the shaft. This worked for me with my '69 column and with some patience, it should work for you also. I hope I didn't leave anything out, but if I did I'm sure someone on the site will chime in. At least I think my spelling and grammar are correct.
Old Dec 26, 2005 | 04:10 PM
68/BB's Avatar
68/BB
well that was a real pita but i got it off. the plastic spacer didnt want to move but i finally got it slipped off then the spring and washer. the bearing had already came completely apart. the ball bearings rolled out and the inner race fell out. unfortunately the outer race had become almost fused to the housing so i had to split it with a carbide cutter then when i tapped it good it came out too. dont you just love working on 37 year old parts that have been together so long they have practically bonded together.
Old Dec 26, 2005 | 07:44 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i soaked mine for several days before i even tried to dissassemble it....and that worked really well
To lower steering column bearing question
