Dead starter?
Old Dec 29, 2005 | 11:10 AM
jbroughton's Avatar
jbroughton
Default Dead starter?
I just finished installing new intake manifold gaskets on my 69. Cranked the car and let it run for about 5 minutes, then shut it off to check for leaks. Everything looked good, so I went to start it again to take it out for a spin, and now it's dead. When I turn the ignition switch, nothing happens. Not even a click from the starter.
Lights and radio still work. When I turn the ignition switch to start it, the ammeter gauge goes to the negative side, about to the first line. I did a quick tug on the wires at the starter and the coil, and didn't see anything obviously loose.
Car is a 350 with a gear reduction mini starter. Over the last 2 months, it has gradually begun to crank slower and slower. I replaced the battery, thinking it was about to die, but that didn't help. Could the starter have just died on me, or should I go back in and check the wiring closer?
Thanks!
Jeff
Old Dec 29, 2005 | 11:57 AM
kb2fzq's Avatar
kb2fzq
I'd like to ask the obvious, so bear with me...auto or 4 speed...why I ask, my 76, "occationally" will not start in the fashion you speak of because the shifter isn't completely in park, a shove forward and she'll fire...I guess you could have a flat spot on the starter, I just can't get on board with these starters just crappin' out all of a sudden, without some pre-notice of major problems...I hope this helps...good luck
Old Dec 29, 2005 | 12:05 PM
jbroughton's Avatar
jbroughton
It's a manual transmission... I tried putting it in gear and rocking it back and forth, thinking that maybe the starter had just bound up in that position, but it didn't help.
Did I read one time that there is a fusible link in the wiring harness near the starter? Could that cause this problem? Would the lights and radio still work if it has melted down?
Jeff
Old Dec 29, 2005 | 12:16 PM
kb2fzq's Avatar
kb2fzq
Hmmm....can ya roll it and pop the clutch to get her started? That might shake something loose that's bound..
The fusable link has been brought up here often, and I can't honestly advise in that area, I don't have any experience regarding the f-link (yet)...plenty of guys on here today, maybe someone else will pop in...
Old Dec 29, 2005 | 12:35 PM
markdtn's Avatar
markdtn
Sounds like the starter to me. You might take it off and test it. Doubt the fusable link has anything to do with it since other stuff works. You might try to jumper the batt terminal to the starter terminal (in neutral of course) to rule out wiring.
GM used gear reduction starters on C4s and 4wd pickups that can be used on earlier engines. I like the Delco rebuilt from Advance or O'Rieleys.
Old Dec 29, 2005 | 12:42 PM
SLVRSHRK's Avatar
SLVRSHRK
I would remove the unit and bench test it with some jumper cables from the battery. If that works, get some emory and make sure all of the contact points between the starter and engine block are clean and connected. Could be a bad ground, had that happen to me after I rebuilt my starter.
Good Luck.
Old Dec 29, 2005 | 03:38 PM
jbroughton's Avatar
jbroughton
Just had the starter checked at Auto Zone, and it's ok.
Found the fusible link... the insulation is all wrinkled and puckered looking, like it's been hot. But if I pull on both ends of it, it appears that the wire inside is all right. Should I replace it to be on the safe side?
Jeff
Old Dec 29, 2005 | 06:35 PM
jbroughton's Avatar
jbroughton
Hmmm, how about the ignition switch? If it went bad, could it cause these symptoms?
The more I think about the fusible link, the more I'm inclined to agree with markdtn - if the fusible link was bad, wouldn't that knock out power to everything?
Sorry guys, but electronics is like black magic to me. I don't know enough to troubleshoot the problem, but I hate to just throw money at it!
Jeff
Old Dec 29, 2005 | 08:20 PM
Sayfoo's Avatar
Sayfoo
Check the easy things first. Battery--lights and small things will work with a bad battery, but not necessiarly the starter. If it hasn't been charging for awhile, it would just slowly go bad. Use a hydrometer and a volt meter. Check battery cable connections and clean/tighten. I have been fooled by bad or discharged batteries before.
Old Dec 29, 2005 | 09:43 PM
jbroughton's Avatar
jbroughton
Thanks for the suggestions glenkov48. The battery is brand new, although I guess even that is no guarantee that it's good. I haven't checked the grounds because I just had the body off the frame last winter and I ASSUMED (and we all know what that gets you ) that they were clean and tight. But you're right, that should be one of the first things to check. I'll take a look at them Saturday before I go any further!
Jeff
Old Dec 30, 2005 | 05:45 AM
kb2fzq's Avatar
kb2fzq
Jeff
If it looks burnt (wrinkled and puckered) as you say, there has been excessive amps going thru it, generating heat and it will pop the fusey link...like it sounds, there is a fuse in the wire itself, but high amps usually means a dead short someplace drawing those amps...if it's not a major project, I'd replace the f-link, but after replacing, grab a hold of the f-link wire, or during starting and feel for heat...that f-link should not be hot to the touch..if it is, you've got worst problems someplace else...the fuse is there to break the circuit before the whole wire goes up in flames..
Old Dec 30, 2005 | 11:28 AM
GUSTO14's Avatar
GUSTO14
... When I turn the ignition switch, nothing happens. Not even a click from the starter.
Car is a 350 with a gear reduction mini starter. Over the last 2 months, it has gradually begun to crank slower and slower. ...
Thanks!
Jeff
Jeff, based on your original post, I would look closely at the ignition switch. I chased the problem you described for a while and ended up rebuilding my starter and replacing the solenoid and still had the problem. Then I looked at the ignition switch (the one on the top of the lower column) ...that solved the problem.
However you went on to say that it began to crank slower over the past 2 months and this would not be consistent with an ignition switch or the reverse start-switch being the problem. Ignition switch problems as well as reverse start-switch problems typically result in no power getting to the starter, but not slow cranking.
I would still test the ignition switch, by jumping the solenoid. The best way to do this is with a remote starter switch that you can get at most good auto parts stores if you don't have one.
http://buy1.snapon.com/catalog/item....re&dir=catalog
This is what I used to eliminate the starter as the problem on mine.
Good luck... GUSTO
Old Dec 30, 2005 | 11:49 AM
kb2fzq's Avatar
kb2fzq
I just finished installing new intake manifold gaskets on my 69.....
Since you've already pulled the starter and had it tested good, here's one more "forest thru the trees" thing...make sure you don't have a wire pinched in that intake you just put back on...that would cause a good start, then a no start if you grounded a hot wire and blew a fuse or such as that in conjunction with the starting circuit somewhere....just a thought...stranger things have happened..
Old Dec 30, 2005 | 11:59 AM
thebruce's Avatar
thebruce
If the ignition wire to the starter looks anything like mine, that's your culprit. The wire you referred to as the fusible link-- if the strands of the wire are separated, then the wire isn't able to carry enough current to engage the solenoid. Replace the wire and it should turn over like it's new. You can check this by bridging two of the terminals on the solenoid with a remote starter (also known as a screwdriver). If it turn with full force, then you've confirmed your problem. Another key indicator is whether the starter turns slower if the engine is warm. Since electrical resistance increases with heat, the ignition wire (which already is putting up some huge resistance) gets to the point that it does not let enough current get to the solenoid. Replace that wire (or at least the starter end of it), and your problem should be solved.
Old Dec 30, 2005 | 05:50 PM
jbroughton's Avatar
jbroughton
OK guys, thanks for the suggestions! That gives me a couple of things to check out this weekend. I'll let you know what I find...
Jeff
To Dead starter?
