valve dilemna
Old Dec 29, 2005 | 11:55 AM
71redskin's Avatar
71redskin
Default valve dilemna
trying to put new valve seals in my 71BB.. i have the #1 cylinder at TDC, put 80# air press in and valve still goes down with the spring. i hear air escaping when i pressurize cylinder. do i have a more serious problem or am i doing something wrong
Old Dec 29, 2005 | 12:33 PM
Jclgodale3's Avatar
Jclgodale3
are you shutting off the compressed air once it reaches 80 psi? Kepp the air flowing (pressurized) and try it that way. Just a thought
Old Dec 29, 2005 | 02:24 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I had the same problem when doing my valve springs - not sure what I was doing wrong. I ended up using rope to keep the valves up. You insert a long piece of rope thru the spark plug hole with the piston partially up in the cylinder (make sure to leave a good amount outside the head so you can pull it out later). Then you rotate the engine by hand until the piston gets close to TDC and compresses the rope in the combustion chamber. This will keep the valves up. Once the springs are back on, rotate the engine backwards and remove the loose rope. Go to next cylinder and start the process all over again.
Old Dec 29, 2005 | 03:50 PM
glen242's Avatar
glen242
Give the retainer a rap with a hammer to free up the retainers, which are probably stuck.
Have used air in the cylinders without a problem. However, if you put the air pressure to the cylinder, with both valves closed, and you hear air leaking, you have another problem.
Old Dec 29, 2005 | 04:56 PM
Brettmc's Avatar
Brettmc
Grayhook and I put my piston at TDC, inserted rope, hit the valve with a dead blow hammer a coupla times to loosen the retainer, the swapped out the seal. No air required, no problems.
Brett
Old Dec 29, 2005 | 05:56 PM
71redskin's Avatar
71redskin
thanx guys... weather permitting i'll give it a try tommorow...talked to my mechanic and he said if i have blue smoke, its rings and time for a rebuild. hoping doin the valve seals takes care of the prob.
Old Dec 29, 2005 | 09:54 PM
Brettmc's Avatar
Brettmc
Same as you, I got conflicting opinions on the origin of my blue smoke. I figured I'd try the seals first. As it turns out, it did fix my smoke problem.
Brett
To valve dilemna
