Anyone Wrap their Headers?/
Old Aug 3, 2001 | 04:38 PM
vettepowA's Avatar
vettepowA
Default Anyone Wrap their Headers?/
Is it hard to do yourself, should i take it in to the shop. What's the best brand to use. Where do you get it? THANK YOU :cheers: :bigears
Old Aug 3, 2001 | 04:53 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Anyone Wrap their Headers?/ (vettepowA)
Ok I just learned hoiw to reply again! I wrapped my old headers and was very happy with the performance and the results. The secret is to take your time ( as usual ;) ) and get the wrap wet before starting to apply. It makes the wrap much easier to handle. You may also have to pry the pipes apart allttle to get between or just wrap both together if that looks like it'll work better.
With the wrap on, it MUCH easier to change plugs, oil, etc..... without burning yourself. I would recommend it to anyone who also wants to lower the cabin temp in their cars also, as it really lowers the heat temp under the hood.
Old Aug 3, 2001 | 05:02 PM
Todbo's Avatar
Todbo
I wrapped a set on a 69 camaro , and I told myself I'd never do that again. But , I just got some more wrap for my 71 BB. This time I bought sleeve wrap which I hope will be alot quicker to do(allows you to wrap 6 - 7" at a time). Summit caries all kinds. :yesnod:
Old Aug 3, 2001 | 06:01 PM
vettepowA's Avatar
vettepowA
Default Re: Anyone Wrap their Headers?/ (mikeo)
Thanks Guys Thats a big help. With the bb and no ac it get really hot in the uh...uh...cabin? :cheers:
Old Aug 3, 2001 | 06:50 PM
AlwaysWave's Avatar
AlwaysWave
A lot of people say not to wrap the headers because the contained heat eats them up in a short time. Anyone have experience with that?
Old Aug 3, 2001 | 07:08 PM
Jay M's Avatar
Jay M
Default Re: Anyone Wrap their Headers?/ (Road Fever)
I think I heard that the wrap can trap moisture, and cause them to rot :( But it seems to me that they would stay so hot that moisture couldn't build up :confused:
~Jay
Old Aug 3, 2001 | 09:03 PM
paso's Avatar
paso
Default Re: Anyone Wrap their Headers?/ (Jay M)
I have the 77 wrapped as it passes the starter only to prevent heat at the starter.
Old Aug 4, 2001 | 10:18 AM
Purplerainz's Avatar
Purplerainz
my 78sa came with duals and wrapped really well . they are on tight around the lower portion by the collectors and half way up . it hasn't loosened yet . my temps are around 190F :D
Old Aug 4, 2001 | 11:05 AM
dlw's Avatar
dlw
I have the hooker super comps and thought that header wrap sounded like a good idea so I called Holley and asked if it was a good thing to do this and their answer was ABSOLUTLEY NOT! They said that it works too good and builds up too much heat and will ultimately destroy the metal.
Old Aug 4, 2001 | 01:21 PM
MoneyPit's Avatar
MoneyPit
I too am thinking of wrapping. I would assume it is a question of economics. I don't really care if it eats the metal as long as I get a couple to thee years of them. Anything that will cool of the cabin in these hot Mississippi summers is okay by me. However, what about a drop in performance. Does the wrap affect the performance of the motor and the ability of the header to scavenge exhaust. It would seem like it could if they were too hot?????? Any comments.
Old Aug 4, 2001 | 03:52 PM
SmokedTires
St. Jude Donor '05
They claim that the wrap will improve performance. From what I've read, the exhaust starts to cool from the moment that it leaves the cyclinder head. As air cools, it becomes more dense, this increasing air density becomes harder to push through the exhaust the further it cools and travels. The idea is to keep the air hotter further down the exhaust so there is less force to get it to exit.
I had my wrap on my headers for 4 years without any problems. My car is only driven in the summer, and ocassionally in the rain. I aslo wrapped the exhaust where it went under the fiberglass spring to keep the heat away from the fiberglass.
Heres a shot of the wrap under the spring.
Old Aug 4, 2001 | 04:03 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Hey Mike, any word on your posi unit?
To Anyone Wrap their Headers?/
