Where does the coolant go?
Old Dec 31, 2005 | 02:04 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Where does the coolant go?
Lately I have been noticing that the level of coolant in the overflow tank seems to drop...I keep adding a little bit and it continues to "find it's own level"...about 3 inches of coolant in the tank....In the past 6 months I have had installed a new heater core, water pump, radiator and all new hoses. I thought maybe I had a blown water jacket....but my oil is perfect....no evidence of water or coolant. Underneath the car.....perfectly dry...No runs, no drips, no errors. So what is ya'll's opinions????
Old Dec 31, 2005 | 02:16 AM
ltlevil's Avatar
ltlevil
May just be evaporating a little, how's the seal on the rad cap look?
ltlevil
Old Dec 31, 2005 | 05:43 AM
supercalvin's Avatar
supercalvin
Sometimes those caps will let some steam away.
Have you noticed any coolant smell?
Old Dec 31, 2005 | 06:45 AM
stingraymaniac's Avatar
stingraymaniac
i had a little leak around the thermostat that got out on the intake and dried there,wery hard to se when you dont see any water....
Old Dec 31, 2005 | 08:50 AM
vetteguy75's Avatar
vetteguy75
At one time the thermosat leaked a little (saw a small puddle of coolant accumulate in the recesses of the intake and/or a stain would be left behind). Tightened the thermostat down and no more puddles or stains. And the coolant level still continues to lower. One question that was posed...."Do I smell any coolant?" Yes...ever so-o-o-o-o slightly...occasionally. And when I do, I immediately look for ANY leaks...and see nothing.....
Old Dec 31, 2005 | 09:25 AM
marshrat99's Avatar
marshrat99
You could also have a small leak in your intake manifold gasket. This not that uncommon. Most leaks can be tested by using a pressure guage that replaces your rad cap. If the pressure guage doesn't show a large leak or none, then I'll recommend using 1 GM stop-leak tablet. Otherwise you'll need to install new intake gaskets.
Old Dec 31, 2005 | 09:29 AM
rihwoods's Avatar
rihwoods
Long shot here,but look up under your front end just at lower radiator support...coolant can collect there and not hit floor..when you drive,it blows off...also check your lower rad hose at clamp.....
Rich
Old Dec 31, 2005 | 09:47 AM
phclub's Avatar
phclub
New England Events Coordinator
Hi, I can offer my similar expereince, I used to add some coolant after every ride (70 350/vert). When I arrived home I would see that the overflow hose was wet from loosing some coolant on the ride. I purchased the R26 (15lb) replacement rad cap (compatible with aluminum system) and the car does not loose collant anymore. The car runs at a cool 180 degrees constant.
It may be worth a try!
Old Dec 31, 2005 | 10:01 AM
Gary79's Avatar
Gary79
all good advice, get your vette all warmed up, coolant levels topped up in the rad and overflow tank, open the overflow tank and check the coolant for bubbles. if you have a steady stream of bubbles, the exhaust is blowing into the water jacket in the motor, it's head gasket replacement time. My 89 Suburban did this, had a 350 in it, and my 93 work truck, with a 454 has done this since new. I've told the mechanic and even showed him the bubbles, but they won't fix it. what happens is the radiator goes out, on my 4th radiator in 64,000 miles on a 1993 GMC 3500 utility bucket truck.
Old Dec 31, 2005 | 10:26 AM
THE ROOSTER's Avatar
THE ROOSTER
My 89 Lebaron( my drive to wok'er)had the same problem, went to local auto parts house & purchased "Bars Heavy Duty Stop Leak", for a V8 add the entire bottle... This was a year ago & last week it finally let go... It's not a fix, just a band-aid, if that's the problem... Also, had to put three 9/64" holes into thermostat and went to a 7lb. radiator cap... Now I'd recommend a 13lb. one,for a V8...
To Where does the coolant go?
