Correct Ride Height
Old Jan 1, 2006 | 12:02 AM
trsulliv's Avatar
trsulliv
Default Correct Ride Height
I just installed semi-coil over shocks in front on my 73 T-top and want to know what the proper ride height is and how/where to measure it. I have the Corvette Assembly manual and found the chart with the drawing but I am not sure how to read it. The chart has multiple car specs, and then are are specs which include different tire sizes. Which spec is right for my 73 small block Coupe? The diagram is very general, so I am not sure if I measure off the lowest part of the frame. Any guidance would be welcome.
Old Mar 14, 2006 | 08:46 PM
audiec's Avatar
audiec
ttt
Old Mar 14, 2006 | 08:48 PM
LittleJake's Avatar
LittleJake
I think you measure from the tip to ground. I remember reading about a post similar to this one, you might want to use the advance search feature and you will probably find your answer.
Old Mar 14, 2006 | 08:49 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Lower her till she scrapes, the back up 1/2"
To Correct Ride Height
