Water pump removal question...
Old Jan 2, 2006 | 09:45 PM
TribalTech's Avatar
TribalTech
2nd Gear
Default Water pump removal question...
1995 LT1: My water pump is leaking and needs to be replaced. When I tried to remove it all of the bolts came out ok and it separated from the engine but it will not come all the way off. It seems to be stuck to the water pump drive shaft. Any thoughts on why it is stuck or what my next course of action should be will be greatly appreciated.
Thank you,
TribalTech
Old Jan 2, 2006 | 09:49 PM
onaqwst's Avatar
onaqwst
might want to repost in the c4/5 section......
or i could be wrong
