QA1 shocks...
Old Jan 3, 2006 | 12:50 PM
panic's Avatar
panic
Default QA1 shocks...
today i've fix the new QA1 shocks under my '77, they look the business and they gave the final touch of performance to my suspension set up, i've tried the car on a motorway climbing a hill at good speed and the change upon the standard konis is more then great, the drive gets crispy and very responsive.
i dont sell these shocks so you can believe me
Old Jan 3, 2006 | 01:05 PM
alanbl's Avatar
alanbl
Based upon your previous recommendation, I checked out the QA1s and had serious sticker shock! I could buy two good bottles of Brunello di Montalcino for the cost of each shock.
By the way, are you using a composite mono leaf spring or the stock or multi leaf steel spring?
Old Jan 3, 2006 | 01:06 PM
Grutzy's Avatar
Grutzy
I put double adjustable QA1's on my car also. They are excellent but not cheap. Those with less money to spend on shocks seem to be satisfied with koni shocks. For those who have the money or no self control when it comes to spending, the QA1's are certainly at the top of the food chain.
Old Jan 3, 2006 | 01:07 PM
Grutzy's Avatar
Grutzy
There's nothing like having your priorities straight.
Old Jan 3, 2006 | 01:24 PM
panic's Avatar
panic
i'd choose a lacrima christi which is a wine grown on the vesuvius volcano, (by the way did anybody ever tried it??)...i have a rear composite monospring with 10'' bolts and front transverse composite kit with 8'' bolts... what i need to refine now is the allignment, a forum member gave me a link from where get proper allignment figures for street and strip..
these shocks worth the expense though...
Old Jan 3, 2006 | 01:29 PM
panic's Avatar
panic
well i thought konis were not bad but now i think they're ...the point is that if you go out of the street and crash you'll be looking to spend thousands (if you can save your life), why not spend some extra money on security, maybe if i had a better handling i wouldnt crash into a bus 4 months ago causing 10.000 euros damage to my car, so what's the cheaper alternative...
Old Jan 3, 2006 | 02:02 PM
Grutzy's Avatar
Grutzy
You don't have to sell me on QA1's, panic. I love them and consider koni's nothing more than low grade rubbish in comparison. However, sometimes I don't have as much money as I wish I had and I can understand if other members cannot afford to pay $1200 for shocks. These corvettes cost a hell of a lot of money to modify and not everyone has the means to go top shelf. They still love their vettes and get my respect just for being C3 enthusiasts. That is about as politically correct as I can be. I'm exhausted. God Bless QA1. They as hell have a place in my heart.
Old Jan 3, 2006 | 04:01 PM
alanbl's Avatar
alanbl
Originally Posted by panic
: i'd choose a lacrima christi which is a wine grown on the vesuvius volcano............these shocks worth the expense though...
Never tried a Lacrima Christi but I'll look for it!
I have no doubt that the QA1s are worth the money but I've read a lot of good things about the Bilstein Sports combined with the composite monospring and I think that's the route I'm going to take. That along with Wilwood brakes should keep me on track in the curves and able to stop when necessary.
Let me know if I'm delusional.
Old Jan 3, 2006 | 05:00 PM
CruisinCO's Avatar
CruisinCO
Alan- I'm local in Thornton and have the QA1 setup with a rear fiberglass spring on my 69 vert. I work in Boulder and drive my car often to work. You're more than welcome to PM me and take it for a spin (as long as it's not Cannonball Run agressive) to see if you like the setup or not. I fell in love with this setup the first time I drove it.
Old Jan 3, 2006 | 05:34 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I didn't see them listed for the rear. Does anyone have a part #?
Old Jan 3, 2006 | 07:03 PM
Lotus76's Avatar
Lotus76
Thats the setup I'm looking at too. I thought the blisteins were the hot setup...
Fill me in on the QA1 why are they so highly thought of now?
Old Jan 3, 2006 | 07:22 PM
Grutzy's Avatar
Grutzy
The QA1's are an aluminum bodied shock. You can get them in different configurations, with the best being the double adjustable shocks. I have the double adjustable and what I like about them is that I can adjust both rebound and compression damping. I like stiff rebound damping because I have a 426lbft rear composite spring and without a firm rebound damping, the rear wants to rebound too quickly. Most shocks offer very little compression damping at all and rely on the springs to take care of that. The QA1's allow you to pump up the compression as well, which will firm up the ride. You can also make it very light if that is what you desire. In my opinion it is barbaric technology when you have a shock without these two adjustments. The QA1 double adjustables are not cheap though. They cost over $300 each. The single adjustables are much less expensive.
Old Jan 3, 2006 | 08:58 PM
shafrs3's Avatar
shafrs3
Grutzy,
Did you buy the coil over conversion or just the shocks?
Old Jan 3, 2006 | 10:13 PM
shafrs3's Avatar
shafrs3
TC1574P for single adj, DTC1574P for double.
Old Jan 4, 2006 | 07:17 AM
Grutzy's Avatar
Grutzy
I bought the standard fit shocks, not the coil over conversion. First, I called QA1 and got the correct part number for my car. Then I called Summit, who had the front shocks and drop shipped the rear shocks from QA1 to my house.
To QA1 shocks...
