6 link Lower Bracket Idea
Old Jan 5, 2006 | 09:25 PM
84rzv500r's Avatar
84rzv500r
Default 6 link Lower Bracket Idea
I just posted a pic under my Corvette photos of the conceptual view of my 6 link lower bracket. I have completed the upper braket drawing as well. It should be approved tomorrow morning.
The drawing is not to scale and no exact measurements are implied it was a quick an dirty 10 minute affair to get started. The thinking here is to get an idea of the machining/plasma cutting/bending/welding operations needed to complete the assembly.
The upper bracket is similar in construction. I'll likely thread the bushing on the front (lower) and back (upper) side to keep from having a nut holding the strut rod in.
Installation will require the removal of the Differential crossmember. Not that it cant be done without, I'm just gonna beef up the crossmember.
thoughts/opinions/feedback?
Old Jan 5, 2006 | 11:17 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I can't find the picture you describe there. What page is it on?
Old Jan 5, 2006 | 11:25 PM
84rzv500r's Avatar
84rzv500r
Page 1, It's not approved yet by the mods.
Old Jan 6, 2006 | 08:06 PM
84rzv500r's Avatar
84rzv500r
http://forums.corvetteforum.com/photopost/direct_data/1076/53923Moonlight_Machine_Corvette_6_Link_L ower_Bracket-thumb.gif
Old Jan 7, 2006 | 08:22 AM
norvalwilhelm's Avatar
norvalwilhelm
You are making it more complicated. Just take the stock bracket and add extensions down.
Forget the upper bracket and just weld studs in the proper location directly to the crossmember.
If you go the bracket route and I went that route twice before I relized the brakcet bolts to the rearend and the rearend bolts to the crossmember. Why not just weld 2 studs directly to the crossmember???
Old Jan 7, 2006 | 08:28 AM
norvalwilhelm
This is the stock crossmember with a 1 ½ inch ears welded on to drop the inner mount
This is a overall shot showing the inner stud welded to the crossmember
This is another shot of the upper strut and inner stud
The length of this arm is critical and is either 13 ½ or 14 ½ inches long. I have it written down at work.
The inner mount location in alignment with the lower inner mount, the universal and the upper mount is critical
This is a far better easier way to do the same thing you are doing with a bolt on bracket.
Old Jan 7, 2006 | 09:47 AM
comp's Avatar
comp
Old Jan 7, 2006 | 10:08 AM
Twin_Turbo's Avatar
Twin_Turbo
Why make it so complex when it really is a pretty simple bracket?
Here's my lower bracket. The top one is much harder to do on 80-82...as in impossbile, you'll need a subframe for them..79 and earlier sure makes life easier there.
Old Jan 7, 2006 | 12:18 PM
groovyjay's Avatar
groovyjay
I like that idea better than the others if that would be made out of billet aluminum.
Old Jan 7, 2006 | 01:22 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
TT is that differential cover/ crossmember aluminum or cast steel ?
Old Jan 7, 2006 | 01:31 PM
Twin_Turbo's Avatar
Twin_Turbo
aluminium
Old Jan 7, 2006 | 01:38 PM
SmokedTires
St. Jude Donor '05
Old Jan 7, 2006 | 01:43 PM
Twin_Turbo's Avatar
Twin_Turbo
it's just a stock 82 diff..nothing fancy.
Old Jan 7, 2006 | 02:21 PM
comp's Avatar
comp
glass beaded ????
Old Jan 7, 2006 | 02:39 PM
84rzv500r's Avatar
84rzv500r
I like Norval's idea for the top!! I was gonna weld the top on anyway, |I can eliminate the bracket on top and just use the post. That saves some work.
I'm gonna use my bracket on the bottom. It will be very simple on our CNC plasma cutter to cut the top and bottom front and back from 0.125 wall tube. drop the spools in and a bit of welding to button it all up. Then a quick trip to the mill to finish.
This forurm is Great !!
Old Jan 7, 2006 | 03:05 PM
Twin_Turbo's Avatar
Twin_Turbo
Originally Posted by comp
glass beaded ????
no cleaned and painted w/ alu spray paint (rustoleum hard hat)
Old Jan 9, 2006 | 10:05 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I agree, your's looks so simple.....
good job
Old Jan 10, 2006 | 09:16 AM
Twin_Turbo's Avatar
Twin_Turbo
that's because it's a later model diff and the plate is originally loctaed backwards and the strut rods have an angle in them, I didn't want my rod ends to be angled but straight so I had to offset the mounting plane further forward....on the <79 it's much easier, just a flat bracket like norvals
To 6 link Lower Bracket Idea
