Intake manifold sealing
Randy
One additional way to check is to use the oil dye sold at NAPA, cleaning area and then use the special light (black light) to see source.
Good luck
Thanks to all of you for your input.
Randy
Randy
1. makes metal cold..very...they will will crystalize contanimates.
2. the metal is porous(sp?) and some cleaners stay in the pores and will NOT allow sealant to adhere properly because of this.
3. they drain into the cracks and stays there...spray pressure forces these cleaners further into the cracks.
4. is NOT compatible with sealants and will eat away the sealing properties.
Yes, these types of cleaners have been used for years with no problems...but when you DO have a problem, its time to go to plan B and start eliminating the causes of sealants not adhering properly.
You can try using a paint de-glosser (Parks makes one, found at s-Lowes, or Home Repo) to clean the surfaces.
1 its very inexpensive(a buck or two a pint), it dries very fast, it will evaporate from pores.
2. it will evaporate any other solvents from pores along with it,
3. doesnt make the metal cold,
4. applies with a rag, can also be applied with a small brush into cracks and other gaskets safely.
5. can be rubbed on vigorously.
6. has no oil whatsoever in it...where as tank solvent cleaners do.
Its also great for cleaning tons of other stuff too...road tar, oily or greasy parts, ect...
And then there is always the use of what its intended for...cleaning something to be prepped for painting. Prepping for a good sealing is the same...but you dont use carb, solvent tank cleaner or brake cleaners to prep before painting right?
The only time I have seen somebody have this much trouble, this many times has been due to:
1. too much pressure in the intake valley and blowing the gaskets/sealant out....the intake valley is seperate from the pressure from underneath the valve covers(though; it shouldnt be)...could be a problem with head gasket not allowing intake valley pressure to be equal throughout engine(wrong head gasket, upside down, or incorrect holes stamped/defective).
2. not allowing the *cleaners* to be completely dry or removed from the surfaces.
3. (oh, this is a doozy) not cleaning the CRACKS where the block and head match...solvents and oils get in the cracks and are absobed into some gaskets...this prevents adhering of sealants (this is where the de-glosser shines, it can be applied with a brush in the cracks and wipes out anything that will prevent adhering...can be blown with a light pressure air tip and applied again and again until thought clean.)
FWIW--I have never had this problem when using rubber or cork gaskets....just put light amount of sealant on on the gaskets and a bead in the corners...always worked for me.
As always---YMMV
Good luck and I hope this helps,
Jim
dont ever do any of this. if you use the gaskets apply a super thin bead of rtv to hol it down a nd a skim coat with ample beads on the ends/corners, on the top. if you use the rtv only, run a nice fat bead with an overlap onto the intale gasket in the corners. and you can install you manifold immedialtly after applying the rtv. and dont clean with brake or parts cleaner unless you plan on changing the oil before startup. only use a scraper or rotary disc and block off all passages and remove all debris. most quality gaskets will come with a sticky bottom to hold it down. i have had luck with both the gaskets and the rtv only. its never been that big of a deal.
