Heater hose replacement
Old Jan 9, 2006 | 10:33 AM
Jim71Vette's Avatar
Jim71Vette
Default Heater hose replacement
How difficult is it to replace the heater hoses on a '71 sb with a/c ?
Old Jan 9, 2006 | 10:38 AM
BerniesVette's Avatar
BerniesVette
It wasn't too bad on my '79 and I installed ball **** shutoff valves on each hose to keep the enterior cool in the summer.
Bernie
Old Jan 9, 2006 | 10:41 AM
Missileman's Avatar
Missileman
If you have the correct molded hoses it is not difficult. You will have to jack up the right side to undo the clamps at the heater core. To prevent splashing of coolant in your face, blow compressed air in the engine side of the hose to empty the hoses and heater core. 71 did not come from the factory with a heater control valve, so if you want to install one now would be a good time.
Old Jan 9, 2006 | 10:42 AM
flood's Avatar
flood
The hoses were easily accessable on my 75. Everything can be done under the hood.
Replacing the Heater Core is the hard part on a car with AC.
To Heater hose replacement
