power brake conversion
Old Jan 11, 2006 | 01:51 PM
gator79's Avatar
gator79
Default power brake conversion
I want to convert my 71 big block to power brakes, do you simply replace the master cyl, two lines from the master and add a booster? I am going to order a complete brake line kit and will just order one for power brakes and it should have the correct lines from the master cyl. also is there a problem with clearance on a 454 with headers and power brakes?
