Noisy Throw-Out Bearing?
Old Jan 12, 2006 | 07:56 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Noisy Throw-Out Bearing?
OK.... a couple summers ago, I installed new clutch, pressure plate, and bearing. Only put about 1000 miles a year on this car. When the weather is cold, on first start up, when I go to back it out of the garage-let the clutch out and this thing (bearing I think) screams. Once the car is driven and warms up, no noise?
It's time to remedy this issue-thoughts anyone?
Old Jan 12, 2006 | 11:03 PM
Z-man's Avatar
Z-man
Does it make the noise in forward gears also? I'm thinking it might just be straight cut reverse gear noise while you are backing up...
Old Jan 12, 2006 | 11:38 PM
mdarney's Avatar
mdarney
I had the exact thing happen to me with a profesional rebuilt clutch. after about a year and 2000 mile I had the same whine. I installed a new throwout bearing as well as a new clutch fork and pivot ball stud, both which were worn severely but not replaced. Everything seems to be working well now. the clutch for and ball stud have to be replaced when doing a clutch or proper adjustment will never happen resulting in early throwout bearing failure. And don't pay the outragous prices through the corvette catalogs for the fork and ball stud, GM still sells both for a fraction of the catalog cost
Old Jan 13, 2006 | 08:30 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Thanks for the replys folks, I've run this thread in C-3 General too.
Doesn't matter which gear, forward, reverse. Only when cold though?
To Noisy Throw-Out Bearing?
