fuel pressure problem?
Well I checked the fuel pressure yesterday and it was a measly 3 psi. Bypassed the reg and got an even 6 psi. Adjusted the reg to 6 psi, took out the sight plugs and flipped on the pump. Christ, fuel spraying everywhere out the plugs! Reset the float level, so now at 6 psi the fuel is at the bottom of the sight holes. Been raining for six weeks now so haven't had it out. Can someone 'splain how the original 3 psi could have an effect on the float level? Could this have fixed the problem? I'm confused...
that sounds like the reverse of whats happening....the needle and seat are what limit and cut off the fuel supply coming in.....the float is what rises and holds the needle closed.....too much fuel pressure will actually push the needle in and submerge the float
The stock fuel pumps are self regulating and work great with a little constant flow of the recirc. Yea i never had luck with any aftermarket regulator as they don't like to control press once the inlet needle seats and the fuel line becomes dead headed - no internal relieve/bypass. Aftermarket reg's might work with a small recirc too but what the heck as the mech pmp has an internal one and any inline regulator will just add more restriction.
1 trick to use is a small orifice to limit return flow - i used 'bout .050".
Now u do need to run a vented tank system as i found out the hard way that with an unvented tank once u fill up the gas tank u will fill up the EVC.
U could just as easily install a recirc with ur existing electric pump too for a try and should work just as well. BTW lar's has a great write-up somewhere (on the corvette facts forum i think) on how to make a recirc for a double inlet Holley/Demon and bend tube & double flares too.
Good luck and i hope this can help or at least let us know if it don't.
cardo0
