Bad lifter?? Need help!
Old Jan 12, 2006 | 10:00 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Bad lifter?? Need help! UPDATE
Coming home today my 73 454 started chugging and rattling then some horrible metal on metal pinging. I was about 5 miles from home so I limped home pulled the valve cover pans and found an exhaust pushrod would go down into the lifter. I assume the lifter is "bad"? tried to remove it with a magnet but no such luck. Next is to pull the intake correct?? Does this make sense to you?
Old Jan 12, 2006 | 10:07 PM
big_G's Avatar
big_G
Yep, check the lifter and the cam lobe.
Old Jan 12, 2006 | 10:16 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Could I have buggered the lobe that quick?
Old Jan 12, 2006 | 11:28 PM
vetteaddic's Avatar
vetteaddic
Is the pushrod bent,is that what you cant pull out or is it the lifter you cant pull,is it still together or did it come off the rocker? Compare with the other rockers to see any difference.
Old Jan 13, 2006 | 07:44 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
I removed the rocker and the pushrod came right out and looks perfect. I tried to slip a magnet into the heads to pull out the lifter but it would only rise about 1/2" (I assume damage to the lifter bottom) I am planning on removing the intake this am and hopefully getting out the "bad" lifter then. What would have caused this?? This rebuild was done right and ony a few thousand ago.
Old Jan 13, 2006 | 08:36 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Lifters can fail, unfortunately
What cam/lifters did you install ? If it's only one of the 16 lifters that failed then a "normal" failure is likely... The fact that you can't pull it out after only a few thousand miles after the rebuild worries me a little...
Old Jan 13, 2006 | 08:40 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default lifter tool
there is a lifter tool you can use aslo before you pull the head. I had mine for a while, but i imagine you can still get on e. it is a t-hendle rod with a ball end that seats in the lifter and lock in when you squeze the handle.
tim
Update
snap makes two versions of this tool new style fromthe one i nabbed from my dad's tool box way back when
S8690 - Hydraulic Tappet Tool
S8692 - Hydraulic Valve Lifter Removal Tool: Includes handle and shaft assembly, slide hammer, and a collet for removing stubborn valve lifters "gummed" up with varnish.
Hope this helps
tim
Old Jan 13, 2006 | 09:03 AM
RATT7's Avatar
RATT7
Just wanted some more info on the lifter problem, Is it possible to remove the lifter while the head and the intake are still on. Actually today I will be installing my crane kool nuts that I will be using in place of my stock rocker nuts, during the process I am going to check the rocker arms and pushrods. I have some concerns about one of my lifters, is it possible to pull the lifter out with a maganet ? And if so, once out is it a matter of just pushing it back in.
Old Jan 13, 2006 | 09:23 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Yes, can be done (I did it once)
You can then inspect the cam lobe and the bottom side of the lifter.
Old Jan 13, 2006 | 10:43 AM
sweethence's Avatar
sweethence
Default sure
Ditto, in fact that is the purpose of the tools i mentioned above, withthe intake out, you done need any special tools
Old Jan 13, 2006 | 10:52 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
unless i'm having a brain fart...which can happen .... i don't see how you could do this with the heads and intake on.....in my head i'm seeing that the pushrod holes are smaller then the lifter diameter....
sometimes you even need to use a degreaser to clean off the varnish that seems to stop the lifters from coming out....
Old Jan 13, 2006 | 11:03 AM
sweethence's Avatar
sweethence
Actually it depends on the heads in question. with the newer generations heads its not possible, as the push rod holes are smaller. but it can be done for sure
Old Jan 13, 2006 | 11:18 AM
RATT7's Avatar
RATT7
Thanks for the tip.
Old Jan 13, 2006 | 03:49 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks to everybody, I bought a lifter puller tool for $10.00 at a local parts house. I removed the lifter with no problems.The bottom of it was worn out. The bottom had worn thru to allow oil to come thru a small hole. I pulled another lifter and found it to be perfect. The cam is my concern now. I plan on putting it back together and checking the amount of "rise" in the rocker arm. This car is not a 1/4 mile car but I want it to be dependable. Was this a freak event or should I pull every lifter to check?
Old Jan 13, 2006 | 04:08 PM
bobs77vet's Avatar
bobs77vet
why not replace all of them? they cost about $80 .
Old Jan 13, 2006 | 05:10 PM
vetteaddic's Avatar
vetteaddic
If the bottom of the lifter is worn so is your cam lobe,change out cam.
Old Jan 13, 2006 | 05:19 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
That's not what I wanted to hear. I thought the same thing but my mechanic friend said not necessarily. Opinions??
To Bad lifter?? Need help!
Old Jan 13, 2006 | 05:33 PM
Les's Avatar
Les
He's probably right. Sometimes the ramp on the cam wears enough that it won't rotate the lifter properly in the bore. If that's the case the cam will do the same thing to the next lifter, not to mention that the wear can continue on the cam itself. If you can't confirm that the lifter was originally flawed and the cam is fine you'd be better off replacing the cam too. Don't ask me how I know! I suggest you also check the lifter bore to make sure a new lifter will rotate freely. Good luck with it.
Old Jan 13, 2006 | 05:37 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
The lifter wore on one side only (1/16") the other side is as long as the replacement.
Old Jan 13, 2006 | 05:45 PM
Les's Avatar
Les
If the wear line is straight it indicates that the lifter wasn't rotating. If you can post a pic we can probably tell if that's the case. I went through this about 1 1/2 years ago on my smallblock- I didn't want to replace my cam either but the experts in my area all agreed that it'd be foolish not to. In my case the lifter rotated freely in the bore, which meant that the problem had to be with the cam.
