3.90 gears
Old Jan 13, 2006 | 10:10 AM
70 LS1's Avatar
70 LS1
Default 3.90 gears
Does anyone make rear end gears in the 3.90 range for early C3's?
Old Jan 13, 2006 | 10:21 AM
GTR1999's Avatar
GTR1999
Richmond, but they do have noise issues at times. A lot of places sell them, I won't use them. I tuned away a couple of jobs because of them too.
Gary
Old Jan 13, 2006 | 10:43 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what does a ring set cost say for 3.73 or something like that and does the clutch pak get reused or is that specific to the gear set?
Old Jan 13, 2006 | 10:54 AM
jimvette999's Avatar
jimvette999
I read that the Richmond Gears (which I have, 3.73:1) are noisy (mine aren't) because they are designed more towards strength than quieter designs are. They indicate right up front that they will make noise like gtr1999 stated. You might get lucky like I did but not likely.
Precision Gear these people might be a good choice
Jim
Old Jan 13, 2006 | 12:48 PM
GTR1999's Avatar
GTR1999
Bob, When I sell gear sets they cost $275 for Tom's. Those are the only ones I work with, because I put my name on the job when it's done. Posi clutches are separate. The kit I put together is now $170.Clutches can be reused if they are not undersize,but for the cost I'd use new solids.The clutches are all the same,no difference for gear sets.
If you have questions PM and I'll go over them.
Gary
Old Jan 13, 2006 | 02:09 PM
PatsLs1vette's Avatar
PatsLs1vette
I ran richmond 3.90's in my 76 for years no problems.
Old Jan 13, 2006 | 03:47 PM
bobs77vet's Avatar
bobs77vet
Gary thanks bob
Old Jan 13, 2006 | 03:50 PM
panchop's Avatar
panchop
i have richmond 3.90s in my 65 now. with a 5 speed. they may be noisy, i don't know i'd have to plug up the sidepipes to find out.
Old Jan 13, 2006 | 04:01 PM
70 LS1's Avatar
70 LS1
When you guys say noisy, what do you mean? What does it sound like?
Old Jan 13, 2006 | 05:26 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
I have Richmond 3.90 with no noise
Old Jan 13, 2006 | 05:46 PM
GTR1999's Avatar
GTR1999
Noise will vary depneding on RPM,the gears, setup method,etc Perfromance gears are cut differently to produce a stronger gear but the trade off is gear whine. If you run loud exhaust then you might not hear it, if you run stock exhaust you will hear it. For the cost comparision of the gears and difference in RPM w/373 vs 390 it wasn't worth it to me.
It would be interesting to see the % of people that have no noise with these gears.
Good luck with your decision and car.
To 3.90 gears
