What glue to use?
Old Jan 13, 2006 | 01:13 PM
ltlevil's Avatar
ltlevil
Default What glue to use?
Replacing the carpet on my rear compartments and was wondering if any special adhesive is required or if I can use 3M "spray adhesive"? Any input is appreciated.
ltlevil
Old Jan 13, 2006 | 01:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I used 3M. No problems.
Old Jan 13, 2006 | 01:24 PM
norvalwilhelm's Avatar
norvalwilhelm
I used contact cement over the wheel wells.
Old Jan 13, 2006 | 02:07 PM
Hvymtlc5's Avatar
Hvymtlc5
If you use 3M glue you need to let it get "tacky" for a few minutes before you start trying to stick carpet to it in those ackward places.
Old Jan 13, 2006 | 02:10 PM
7T4StingRay's Avatar
7T4StingRay
Default 3m
They sell a "heavy duty" version available at Home Depot. Worked well on mine.
Old Jan 13, 2006 | 04:22 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
ltlevil
theres two types one is a repositionable and the other is more permanent ....its good stuff
Old Jan 13, 2006 | 04:24 PM
kona's Avatar
kona
Used 3m spray.
Kona
Old Jan 13, 2006 | 06:26 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
that heavy duty 3M spray adhesive is some nasty stuff
Old Jan 13, 2006 | 06:38 PM
lowbuck72's Avatar
lowbuck72
The good stuff is called 3M "777". It's expensive, but works great, watch your overspray, it will clean up with a little petrol on a shop towel.
Old Jan 13, 2006 | 08:48 PM
carriljc's Avatar
carriljc
Default I used clear RTV....
I noticed that they tend to use it at work for just about everything. Works great, remains pliable, and carpet can be easily removed, RTV removed, and reinstalled; if necessary.
Old Jan 13, 2006 | 11:16 PM
ltlevil's Avatar
ltlevil
Thanks guys-appreciate all the info. I'll see what's available tomorrow and give it a go, may end up using a couple of different things depending on the areas.
ltlevil
Old Jan 14, 2006 | 12:43 AM
Fubba's Avatar
Fubba
Used 3M as well about a year ago. Still holding on strong.
To What glue to use?
